How to upgrade IOS for WS-C4506-E switch
vinayak2010
We are having Cisco WS-C4506-E switch running on old IOS. we need to upgrade IOS of this switch.
Can anyone please tell me how to upgrade Cisco 4500 series switches ?
Show module information as below -
Chassis Type : WS-C4506-E
Power consumed by backplane : 0 Watts
Mod Ports Card Type                              Model              Serial No.
 1     6  Sup 7L-E 10GE (SFP+), 1000BaseX (SFP)  WS-X45-SUP7L-E
 2    48  10/100/1000BaseT UPOE E Series         WS-X4748-UPOE+E
 3    48  10/100/1000BaseT UPOE E Series         WS-X4748-UPOE+E
 4    48  10/100/1000BaseT UPOE E Series         WS-X4748-UPOE+E
 5    48  10/100/1000BaseT UPOE E Series         WS-X4748-UPOE+E
 6    48  10/100/1000BaseT UPOE E Series         WS-X4748-UPOE+E
 M MAC addresses                    Hw  Fw           Sw               Status
 1 0006.f609.4d40 to 0006.f609.4d45 1.1 15.0(1r)SG3  03.03.00.SG      Ok
 2 0006.f6da.7c50 to 0006.f6da.7c7f 1.1                               Ok
 3 4403.a78f.f94c to 4403.a78f.f97b 1.1                               Ok
 4 0006.f671.13d0 to 0006.f671.13ff 1.1                               Ok
 5 b0fa.ebca.7d70 to b0fa.ebca.7d9f 1.1                               Ok
 6 0006.f699.ad84 to 0006.f699.adb3 1.1                               Ok
We want to upgrade to 03.04.00.SG .
Bilal Nawaz
Hello, Please see Cisco documentation: Upgrading Software Images on Catalyst 4000/4500 Series Switches
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-4000-series-switches/27848-179.html
hth.
Edited: Please be aware that several recent releases of the 4500 code ignores the startup config and goes to ROMMON once you have upgraded, fix this by sorting the configreg.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Bilal Nawaz
hth.
nkarthikeyan
Level 7
Level 7
Its just like the regular IOS upgrade.
run tftp server in your machine with IOS in a folder and mapped to it.
If you have that switch in live network.... then just try the regular commands
copy tftp: flash:
ip address < machine ?
ios name
ios name
then boot parameters
save and check sh bootvar
if reqd change the conf register value
reload... once done...
Karthik
Hello Karthik,
It's not quite like regular IOS upgrade - it actually depends. Its more like the 6500 upgrades. Here we are dealing with a SUP7, so I think it will be bootflash: not flash:
yeah... it can be bootflash... or disk or sup-bootflash whichever is available flash system in the switch..... i was just mentioning about a generic way.....
Karthik
