How to Upgrade IOS from Master switch to Member switch in catalyst switch 3750
Praveen4848
Hi All,
Can anyone help me in upgrading IOS from Master Switch to Member Switch in catalyst switch 3750.
Praveen.
Reza Sharifi
If the member switch has enough room in its flash, you can copy from flash1 to flash2:
copy flash1 <ios> flash2
ahmedshoaib
Level 4
Level 4
Hi;
You can copy the OS from Master switch to member switch.
Take a example your switch 1 is master then copy the IOS to member switch via below command:
copy flash1:/c3750-ipbasek9-mz.X.X.bin flash2:/c3750-ipbasek9-mz.X.X.bin
and so on all the member switches.
then verify the IOS is copied via dir flashX:
change the boot var: boot system switch all flash:<new_image>
save config and verify show bootvar & reload the switch.
Thanks & Best regards;
