How to upgrade IOS
scooter817
Level 2
Level 2
I wanted to know if someone could explain to me the steps needed to upgrade an ios.I've looked on the internet but i can't find any good informaiton.I have the TFTP software but other than that i don't know how to proceed.Any help would be greatly appreciated and thanks in advance
keeleym
Level 5
Level 5
Hi Scooter817
Before you start the actual upgrade can I ask the following questions please.
1. What equipment are you planning to upgrade the IOS on? Switch/Router and what model?
2. What IOS version is currently on this equipment?
3. How much DRAM and Flash memory does your equipment currently have?
4. What IOS version are you planning on upgrading to?
5. What size is this IOS version?
These questions should be answered prior to starting any upgrade as you need to ensure that your Router/Switch has enough resources to run the new IOS version.
Best Regards,
Michael
5 Replies 5
keeleym
Level 5
Level 5
Hi Scooter817
Best Regards,
Michael
It's a 4510R switch and i will go over to the other building where they are at and find out and i will be right back
2. What IOS version is currently on this equipment? 12.2 (25)
3. How much DRAM and Flash memory does your equipment currently have? 512 Dram 128 Flash
4. What IOS version are you planning on upgrading to? 12.2 (31)
cat4500-entservicesk9-mz
Size 12028080
Hi Scooter817
This image (if I am not mistaken) is around 12/13mb in size so there should be lots of space in flash to hold this. But just to confirm you should run the command "dir flash:" Also 512mb DRAM should be more then enough to run this image.
Before you start you should back up the current IOS image to your tftp server with the command "copy flash tftp". You might want to run "show version£ first to check the name of the current image.
This Cisco document shows the procedure for upgrading a Catalyst 4500 switch, http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a00801347e2.shtml
Best Regards,
Michael
Thanks a million this is really helpful,I going to go home tonight and practice on my presonal switches and i will do this on Monday
