how to use ACL to limit eigrp and ospf traffic?
dannan lin
hi:
i know OSPF ,EIGRP and RIP are both network layer protocols .
and RIP uses UDP at port 520
EIGRP uses RTP and  protocol number is 88
OSPF 's protocol number 89
both EIGRP and RTP are encapsulated into a IP packet 。
alright, if i want to use ACL to limit EIGRP or OSPF update information what port number shall i use ?
in RIP case i can put " access-list  1 deny udp any any eq 520"  but how to do it with EIGRP and OSPF ??
anyone?
thanks in advance
6 Replies 6
vipinrajrc
Level 3
Level 3
you can use passive-interface command to limit routing protocol updates.
Please try that.
Hope that helps
Vipin
Thanks and Regards, Vipin
vikz230884
Hi Dannan,
Not sure if I get this right..
Are you want to block the ospf packet or the routes ?
If packet then "deny ospf any any" same with eigrp "deny eigrp any any"
if the routes you can use distribute-list.
HTH,
Vikram
No this will not work !!
kamomil
access-list 90 remark 10.1.15.2 is your eigrp neighbor's address.
access-list 90 permit eigrp host 10.1.15.2 any
access-list 90 deny eigrp any any
access-list 90 permit ip any any
interface ethernet0/0
ip access-group 90 in
debug ip packet 90 detail
Or you can also do something like:
ip access-l ext EIGRP-Neighbor3-Allow
 !  permit eigrp host 10.1.15.3 host 10.1.15.2 if you used the neighbor statement for unicast EIGRP.
   permit eigrp host 10.1.15.3 host 224.0.0.10
   deny eigrp any any
   permit ip any any
int vlan 15
   ip add 10.1.15.2 255.255.255.0
   ip access-group EIGRP-Neighbor3-Allow in
ip access-l ext EIGRP-Neighbor2-Allow
   !  permit eigrp host 10.1.15.2 host 10.1.15.3 if you used the neighbor statement for unicast EIGRP.
   permit eigrp host 10.1.15.2 host 224.0.0.10
   deny eigrp any any
   permit ip any any
int vlan 15
   ip add 10.1.15.3 255.255.255.0
   ip access-group EIGRP-Neighbor2-Allow in
Hello
Can you elaborate on what you mean by
Kind Regards
Paul
PaulSmith
For EIGRP you can use the built in feature;
router eigrp 50
 distribute-list 30 in TenGigabitEthernet1/1/29
 distribute-list 30 in TenGigabitEthernet2/1/29
 network 10.203.16.0 0.0.0.255
