11-16-2017 10:18 AM - edited 03-08-2019 12:46 PM
We implemented auto qos on our 2960's access ports and uplink ports to support Cisco Jabber. How can we verify that QoS is working?
interface GigabitEthernet1/0/19
switchport access vlan 301
switchport mode access
switchport voice vlan 64
power inline auto max 15400
srr-queue bandwidth share 1 30 35 5
priority-queue out
auto qos voip cisco-softphone
spanning-tree portfast
service-policy input AUTOQOS-SRND4-SOFTPHONE-POLICY
end
interface GigabitEthernet5/0/48
switchport mode trunk
priority-queue out
mls qos trust dscp
auto qos trust
end
Solved! Go to Solution.
11-16-2017 12:06 PM
Try "show mls qos interface gigX/X/X statistics". Apparently there's a bug stating the initial command I supplied is invalid due to hardware limitations.
11-16-2017 11:49 AM
show policy-map interface X/X
11-16-2017 11:52 AM
Okay, so that's what I thought, but not what I was hoping for. It seems to me that it's not working then? Where do I go from here?
switch#sh policy-map interface gi1/0/19
Service-policy input: AUTOQOS-SRND4-SOFTPHONE-POLICY
Class-map: AUTOQOS_VOIP_DATA_CLASS (match-all)
0 packets, 0 bytes
5 minute offered rate 0000 bps, drop rate 0000 bps
Match: ip dscp ef (46)
Class-map: AUTOQOS_MULTIENHANCED_CONF_CLASS (match-all)
0 packets, 0 bytes
Match: access-group name AUTOQOS-ACL-MULTIENHANCED-CONF
Class-map: AUTOQOS_BULK_DATA_CLASS (match-all)
0 packets, 0 bytes
Match: access-group name AUTOQOS-ACL-BULK-DATA
Class-map: AUTOQOS_TRANSACTION_CLASS (match-all)
0 packets, 0 bytes
Match: access-group name AUTOQOS-ACL-TRANSACTIONAL-DATA
Class-map: AUTOQOS_SCAVANGER_CLASS (match-all)
0 packets, 0 bytes
Match: access-group name AUTOQOS-ACL-SCAVANGER
Class-map: AUTOQOS_SIGNALING_CLASS (match-all)
0 packets, 0 bytes
Match: access-group name AUTOQOS-ACL-SIGNALING
Class-map: AUTOQOS_DEFAULT_CLASS (match-all)
0 packets, 0 bytes
Match: access-group name AUTOQOS-ACL-DEFAULT
Class-map: class-default (match-any)
0 packets, 0 bytes
Match: any
switch#
11-16-2017 12:06 PM
11-16-2017 01:27 PM
switch#show mls qos interface gi2/0/21 statistics GigabitEthernet2/0/21 (All statistics are in packets) dscp: incoming ------------------------------- 0 - 4 : 115878134 0 0 0 0 5 - 9 : 0 0 0 0 0 10 - 14 : 0 0 0 0 0 15 - 19 : 0 0 0 1840 0 20 - 24 : 0 0 0 0 0 25 - 29 : 0 0 0 0 0 30 - 34 : 0 0 0 0 0 35 - 39 : 0 0 0 0 0 40 - 44 : 0 0 0 0 0 45 - 49 : 0 294867 0 0 0 50 - 54 : 0 0 0 0 0 55 - 59 : 0 0 0 0 0 60 - 64 : 0 0 0 0 dscp: outgoing ------------------------------- 0 - 4 : 184920242 0 898 0 63 5 - 9 : 0 0 0 165026 0 10 - 14 : 6 0 0 0 0 15 - 19 : 0 0 0 8940 0 20 - 24 : 4 0 0 0 434421 25 - 29 : 0 0 0 0 0 30 - 34 : 0 0 0 0 9358 35 - 39 : 0 0 0 0 0 40 - 44 : 0 0 0 0 1 45 - 49 : 0 7234479 0 2737842 0 50 - 54 : 180 0 0 0 0 55 - 59 : 0 0 0 0 0 60 - 64 : 0 0 0 0 cos: incoming ------------------------------- 0 - 4 : 116206577 0 0 0 0 5 - 7 : 0 0 0 cos: outgoing ------------------------------- 0 - 4 : 196092323 167633 10778 19370 15946 5 - 7 : 128287 43870 2496850 output queues enqueued: queue: threshold1 threshold2 threshold3 ----------------------------------------------- queue 0: 0 0 127657 queue 1: 6164217 308425 2546099 queue 2: 0 0 40247895 queue 3: 165026 6 149598665 output queues dropped: queue: threshold1 threshold2 threshold3 ----------------------------------------------- queue 0: 0 0 0 queue 1: 0 0 0 queue 2: 0 0 1077 queue 3: 4209 0 3095 Policer: Inprofile: 1020040 OutofProfile: 115404
