HP JD092B SFP - Does this work with a Cisco 3850 or Cisco 4500X switch?
Oliver A
Guys,
Need some input.  Does anyone know if this model SFP will work with Cisco 3850/4500X switches?
HP JD092B
https://h20195.www2.hpe.com/v2/default.aspx?cc=id&lc=en&oid=4179912
Thanks in advance!
marce1000
 - Below are a few informational threads on the matter which you may find useful :
     https://community.cisco.com/t5/optical-networking/enquiry-on-hp-fiber-transciever-module-compatibility/td-p/2093433
    https://community.cisco.com/t5/switching/hp-sfp-compatibility/td-p/1658663
 M.
Reza Sharifi
Hi Oliver,
Cisco is very particular about using other vendors's parts. So, it is hard to tell if other vendors's e.g dell, HP, etc..optics work with Cisco's equipment without actually trying it. I would try it, and if it does not work, you can order from this vendor, which I have used several times in the past and their optics works well with Cisco's equipment.
www.fs.com
