HP NIC Teaming with Cisco switch
July sall
Hi all,
currently we have a HP DL360 with 2* NC373i nic on the server and it is connected to the cisco 3750switch
on the server we have SLB setup and with auto loadbalaning (assuming it will use TCP to load balance)
on the switch have 1 portchannel setup with channel-group 1 mode active setup on the port.
we have seen, 2gb TX, RX showing on the HP software however
when we do a TX a large file toward one server (1ip, mac) the speed will stay at 1gb tx
when tx 2file to 2 server we will get 2gb tx speed.
however RX is always stay at 1gb no mater if i copy from single source or multi source. (cisco switch have setup load balanceing from source MAC)
i have question that if anyone have successfuly config
1. HP and cisco switch with a point to point file copy and achieve 2GB TX and RX speed? ( so we can save and not buying 10GB card/switch)
2. how to achieve a 2gb RX speed on this setup?
i have tried this doc, no luck with 802.3ad as the HP software will only reconize the RX port is 1gb only.
http://www.cisco.com/en/US/tech/tk389/tk213/technologies_configuration_example09186a008089a821.shtml
thanks in advance.
burleyman
Level 8
Level 8
I have this setup with the following command and selections.
On the Cisco switch...
interface Port-channel55
description HPServer EtherChannel
switchport
switchport access vlan 3
switchport mode access
spanning-tree portfast
interface GigabitEthernet5/10
channel-group 55 mode active
interface GigabitEthernet5/11
On the server.....
Team Type Selection:
802.3ad Dynamic with Fault Tolerance
Transmit Load Balancing Method:
Destination IP Address
Go into the Infomation tab and verify
under the "Role" columb that both
NICs show Tx/Rx
Mike
7 Replies 7
burleyman
Level 8
Level 8
switchport
On the server.....
NICs show Tx/Rx
Mike
thanks heaps mike,
i'll give it a try soon.
also just want to know if you have achived 2gb speed TX and RX between 2 servers? ( a true 2gb nic output on copying to one destination, rather than load balancing 1gb to 1 server and 1gb to the 2nd server)
thanks
Jon
I did not personally test it but was told it did. if you look at yours under the infromation tab you will probally see one NIC is Tx/Rx and one link is Tx only, this is why you are seeing the Rx only doing 1Gb
Mike
hi mike
thanks for the update, i managed to get it working with one server towards multi-dest RX/TX achieved 2gb speed.
i think with lacp, one to one copy will be limited to 1gb speed. (unless anyone know how???? would love to have my backup server copying at 2gb speed)
the only thing i think i did do before is shutdown both nic and and no sh again. also i have applied portfast on port-channel.
cheers
jon
Hey Mike -
Thanks for your corect answer above... almost 3 years ago but still helpful!  I used to force the Cisco switch to mode "on" (EtherChannel only) and then set the server side to "switch-assisted load balancing" by "destination MAC address" but that didn't seem to work with the 373i adapter (it's an HP ProLiant DL380 G5).
Here, I am using the exact settings as you stated, plus all other checkboxes are set to the defaults.  Yet, while network connectivity for the server is fine the NIC utility tells of a "Failed (LACP)" second team member.  It's very puzzling to me as I cannot find anything wrong... seen this before?
Matthias
  Without seeing the switch  etherchannel config it is hard to say .  In a working   1 gig etherchannel ,any one single conversation will only transfer at 1 gig  as the given ip conversation will go down a single port in the port channel due the channel hashing algorithm . This is normal .
Below is the config and some show commands.  Note how the second switch interface is up but line protocol down (monitoring):
>>>>>>>>>> relevant config details Cisco 3560G version  15.0(2)SE >>>>>>>>>>
description CASSINI (LAN TEAM 1+2)
switchport access vlan 101
interface GigabitEthernet0/19
description CASSINI (LAN 1)
channel-group 5 mode active
interface GigabitEthernet0/20
description CASSINI (LAN 2)
>>>>>>>>>> show etherchannel 5 detail >>>>>>>>>>
Group state = L2
Ports: 2   Maxports = 16
Port-channels: 1 Max Port-channels = 16
Protocol:   LACP
Minimum Links: 0
                Ports in the group:
Port: Gi0/19
Port state    = Up Mstr Assoc In-Bndl
Channel group = 5           Mode = Active          Gcchange = -
Port-channel  = Po5         GC   =   -             Pseudo port-channel = Po5
Port index    = 0           Load = 0x00            Protocol =   LACP
Flags:  S - Device is sending Slow LACPDUs   F - Device is sending fast LACPDUs.
        A - Device is in active mode.        P - Device is in passive mode.
Local information:
                            LACP port     Admin     Oper    Port        Port
Port      Flags   State     Priority      Key       Key     Number      State
Gi0/19    SA      bndl      32768         0x5       0x5     0x114       0x3D
Partner's information:
Port      Flags   Priority  Dev ID          Age    key    Key    Number  State
Gi0/19    SA      0         0023.7db5.1718   2s    0x0    0x300  0x100   0x3D
Age of the port in the current state: 0d:00h:43m:59s
Port: Gi0/20
Port state    = Down Not-in-Bndl
Port-channel  = null        GC   =   -             Pseudo port-channel = Po5
Local information:
Gi0/20    SA      down      32768         0x5       0x0     0x115       0x45
Age of the port in the current state: 0d:21h:02m:11s
                Port-channels in the group:
Port-channel: Po5    (Primary Aggregator)
Age of the Port-channel   = 0d:21h:02m:11s
Logical slot/port   = 2/5          Number of ports = 1
HotStandBy port = null
Port state          = Port-channel Ag-Inuse
Protocol            =   LACP
Port security       = Disabled
Ports in the Port-channel:
Index   Load   Port     EC state        No of bits
  0     00     Gi0/19   Active             0
Time since last port bundled:    0d:00h:43m:59s    Gi0/19
Time since last port Un-bundled: 0d:00h:44m:14s    Gi0/19
>>>>>>>>>> show interface Port-Channel 5 >>>>>>>>>>
Port-channel5 is up, line protocol is up (connected)
  Hardware is EtherChannel, address is 0024.c4c1.ea93 (bia 0024.c4c1.ea93)
  Description: CASSINI (LAN TEAM 1+2)
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, link type is auto, media type is unknown
  input flow-control is off, output flow-control is unsupported
  Members in this channel: Gi0/19
  Last input never, output 00:00:01, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 57000 bits/sec, 13 packets/sec
  5 minute output rate 516000 bits/sec, 59 packets/sec
     4419609 packets input, 1640918832 bytes, 0 no buffer
     Received 20574 broadcasts (18849 multicasts)
     0 watchdog, 18849 multicast, 0 pause input
     9881826 packets output, 12568928384 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
>>>>>>>>>> show interface GigabitEthernet0/19 >>>>>>>>>>
GigabitEthernet0/19 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 0024.c4c1.ea93 (bia 0024.c4c1.ea93)
  Description: CASSINI (LAN 1)
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
  Last input 00:00:23, output 00:00:00, output hang never
  5 minute input rate 69000 bits/sec, 16 packets/sec
  5 minute output rate 534000 bits/sec, 62 packets/sec
     4430108 packets input, 1643006942 bytes, 0 no buffer
     Received 27552 broadcasts (25468 multicasts)
     0 watchdog, 25468 multicast, 0 pause input
     10036411 packets output, 12593153545 bytes, 0 underruns
>>>>>>>>>> show interface GigabitEthernet0/20 >>>>>>>>>>
GigabitEthernet0/20 is up, line protocol is down (monitoring)
  Hardware is Gigabit Ethernet, address is 0024.c4c1.ea94 (bia 0024.c4c1.ea94)
  Description: CASSINI (LAN 2)
  Last input never, output 00:47:43, output hang never
  5 minute output rate 1565000 bits/sec, 736 packets/sec
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     76035912 packets output, 19136874989 bytes, 0 underruns
##### end #####
