HRSP over L3 switch & Routers
Darren Candlish
Hello Everyone,
My devices are;
L3 3550, L2 2550, three routers and two end devices.
I would like to setup HRSP with the L3 switch, routers and end devices but muddled up with the config.
I have dhcp addresses to my end devices through the L3 vlan 100 svi and my L3 connected to a router from a routed port. I would like the redundancy for the end devices through the L3 and routers, but unable to figure the best design practice. I have the attached my configs if anybody can help me. I am currently studying the CCNP and would like to try this on my labs as well as VRRP and GLBP.
Appreciations to any feedback
Hello Darren,
Please check this link I hope it will help you with HSRP configuration:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3550/software/release/12.1_12c_ea1/configuration/guide/swhsrp.html
The example is for 3550 switch.
HTH,
Alex
*Please rate hepful posts
