HSPR on two routers connected thr' fa port
sachinrwani
I want to connect two 1841 router back to back with fast ethernet port.
Please help me how to configure HSRP on two routers connected back to back through fast ethernet port and how to configure fa port to connect the two routers.
Sachin
royalblues
Level 10
Level 10
Sachin,
Two routers can be connected back to back with a cross cable. The IP address of the interfaces should be in the same subnet to work.
I didn't understand the need for HSRP in this. HSRP can be considered as a gateway redundancy protocol. when you have the routers connected backtoback, none of your machines can use the HSRP ip address as their gatewat.
HTH, rate if it does
Narayan
