HSRP and load balancing between 2 6509 switch
charleskoh
hi there, im quite new to these and i want to ask u guys
if 1 have 2 6509 with identical modules installed, lets assume that each of it have 1 MSFC installed
how can i acheived link redundancy and load balancing? can someone explain with diagram??
lets also assume i have 6 Vlans in total where i want odd number vlan goes to sw1, even to sw 2.... how can i acheive that? using HSRP? how?
5 Replies 5
paddyxdoyle
Level 6
Level 6
HSRP can be used to load share VLANs across two switches but not load balance.
For example, you can set up HRSP so that the default gateway for VLAN2 is active on switch one and the default gateway for VLAN3 is active on switch two by setting the priorities of the standby group. Should switch 1 fail, the the virtual interface for VLAN2 will fail over to switch 2 and vice versa.
switch1
int vlan 2
ip address 10.1.2.2 255.255.255.0
standby 3 ip 10.1.2.1
standby 3 preempt
int vlan 3
ip address 10.1.3.2 255.255.255.0
standby 3 ip 10.16.2.1
standby 3 preempt
standby 3 priority 95
switch2
int vlan 2
ip address 10.1.2.3 255.255.255.0
standby 3 preempt
int vlan 3
ip address 10.1.3.3 255.255.255.0
standby 3 preempt
If you want odd VLANs to be active on switch1 and even on switch2 then you can just change the priorities of the standby groups to suit.
There's a good document here which should answer all your questions:
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a0080094afd.shtml
Paddy
ankurbhasin
Level 9
Level 9
Hi Charleskoh,
Yes you can ofcourse achieve this via HSRP.
Check this link.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/sw_7_2/confg_gd/redund.htm#wp1058202
It will give you a complete knowledge of redundancy config in cat6000 switch and also how you can achieve redundancy between 2 chassis even if you have 2 msfc in each chassis.
Ankur
charleskoh
can i do it this way?? so even goes to sw1, odd goes to sw2
switch1
int vlan 2
standby 3 preempt
int vlan 3
standby 3 ip 10.1.3.1
standby 3 preempt
int vlan 4
ip address 10.1.4.2 255.255.255.0
standby 3 ip 10.1.4.1
standby 3 preempt
int vlan 5
ip address 10.1.5.2 255.255.255.0
standby 3 ip 10.1.5.1
standby 3 preempt
switch2
int vlan 2
standby 3 preempt
int vlan 3
standby 3 preempt
int vlan 4
ip address 10.1.4.3 255.255.255.0
standby 3 preempt
int vlan 5
ip address 10.1.5.3 255.255.255.0
standby 3 preempt
Yes, that's why i posted it
One more thing that i would like to mention make sure that sw1 is root bridge for odd vlan's and sw2 is root bridge for even vlan.
you can use this commands
sw1
set spannig-tree vlan 3 5 7 root primary
sw2
set spannig-tree vlan 2 4 6 root primary
And make sure that you are using pervlan spanning tree in your network.
Thanks and Regards
