hsrp between 2821 router and 3750 switch
raj_bjs77
Is it possible to do hsrp between 2821 router and 3750 switch.
Also whether we can do hsrp between two interface on the same router for link redundancy.
6 Replies 6
bjornarsb
Level 4
Level 4
According to Feature Navigator 3750 does not support HSRP.
Try bundling instead of HSRP on same router.
BR,
Bjornarsb
mahmoodmkl
Level 7
Level 7
I think it is possible to do HSRP between 2821 and 3750.
What is the use of doing HSRP on the same device.Suppose if that device fails then u will not have any redundency.
Mahmood
mohammedmahmoud
Level 11
Level 11
Yes you can, both support HSRP, kindly use the Cisco feature navigator to find the correct IOS to use:
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Select "HSRP - Hot Standby Router Protocol".
But note, HSRP is applicable only if you have 2 routing devices, if only one router you can't use HSRP, here you are a post that discussed this item nicely:
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=LAN%2C%20Switching%20and%20Routing&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1ddea6a7
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
Want to know if i can use HSRP between 2821 and 3750 switch for redundancy.
My one link will be connected to 2821 and other to 3750 switch. I will enable L3 on the switch.
Yes you can go for it, please see the link below for HSRP configuration:
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a008042fbb3.html
http://www.cisco.com/univercd/cc/td/doc/cisintwk/ics/cs009.htm
Mohammed Mahmoud.
bjornarsb
Level 4
Level 4
sorry, I did not use CAT37.....
