HSRP Between 6509 pair and a 9500 stackwise
NETAD
Level 4
Level 4
Hello, is it possible to add a pair of 9500's configured in a stackwise virtual to HSRP group configured between 2 6509's?
It does not appear that it is supported:
All Layer 3 neighboring devices must be an NSF helper or NSF-capable to support graceful restart
capability.
• For IETF, all neighboring devices must be running an NSF-aware software image.
The Hot Standby Routing Protocol (HSRP) is not supported with NSF SSO. Do not use HSRP with NSF
SSO.
• An NSF-aware device cannot support two NSF-capable peers performing an NSF restart operation at
the same time. However, both neighbors can reestablish peering sessions after the NSF restart operation
is complete.
Here is a link to the document:
see page-2
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9500/software/release/16-10/configuration_guide/ha/b_1610_ha_9500_cg.pdf
Reza Sharifi
So, one 6509 is active HSRP and the other one is standby and you want to add a second standby switch that is configured as Stackwise virtual?
Yes Reza. For migration purposes so the the ARP table doesn't have to change on the endpoints when we swing L3 to the new 9500 core.
capability.
SSO.
is complete.
see page-2
