HSRP disabled on Switch L3 4507
Nicolás León
Hi, i have a network with redundancy HSRP between my two cores, but  one of them
it stopedd working (CORE1). does not recongnize standby commands, i try to enable with standby console enable command but it does not work. Attach images !
The information from two Core's is the following:
(INFORMATION FROM CORE1 WITH HSRP DISABLED) :
Chassis Type : WS-C4507R+E
Power consumed by backplane : 40 Watts
Mod Ports Card Type Model Serial No.
1 48 10/100/1000BaseT EEE (RJ45) WS-X4748-RJ45-E CAT1625L1SR
2 12 10GE SFP+ WS-X4712-SFP+E CAT1629L16E
3 4 Sup 7-E 10GE (SFP+), 1000BaseX (SFP) WS-X45-SUP7-E CAT1809L3A0
M MAC addresses Hw Fw Sw Status
1 d48c.b5e1.6ee0 to d48c.b5e1.6f0f 1.1 Ok
2 a493.4c5f.5548 to a493.4c5f.5553 1.1 Ok
3 30f7.0d06.6700 to 30f7.0d06.6703 2.1 15.0(1r)SG5 03.04.06.SG Ok
Mod Redundancy role Operating mode Redundancy status
3 Active Supervisor RPR Active
SOLCL-CORE1-TI#sh redundancy
Redundant System Information :
Available system uptime = 41 weeks, 5 days, 22 hours, 23 minutes
Switchovers system experienced = 0
Standby failures = 0
Last switchover reason = none
Hardware Mode = Simplex
Configured Redundancy Mode = RPR
Operating Redundancy Mode = RPR
Maintenance Mode = Disabled
Communications = Down Reason: Simplex mode
Current Processor Information :
Active Location = slot 3
Current Software state = ACTIVE
Uptime in current state = 41 weeks, 5 days, 22 hours, 22 minutes
Image Version = Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (c
at4500e-UNIVERSALK9-M), Version 03.04.06.SG RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Mon 04-May-15 02:44 by prod
BOOT = bootflash:cat4500e-universalk9.SPA.03.04.06.SG.151-2.SG6.bin,12;
Configuration register = 0x2102
Peer (slot: 4) information is not available because it is in 'DISABLED' state
(INFORMATION FROM CORE2 WITH HSRP DISABLED)
SOLCL-CORE2-TI#show module
1 48 10/100/1000BaseT EEE (RJ45) WS-X4748-RJ45-E CAT1640L2XE
2 12 10GE SFP+ WS-X4712-SFP+E CAT1641L2JU
3 4 Sup 7-E 10GE (SFP+), 1000BaseX (SFP) WS-X45-SUP7-E CAT1642L6WJ
1 e4d3.f186.df00 to e4d3.f186.df2f 1.1 Ok
2 e4d3.f1fd.d360 to e4d3.f1fd.d36b 1.1 Ok
3 6c20.5691.ab40 to 6c20.5691.ab43 2.1 15.0(1r)SG5 03.03.00.SG Ok
3 Active Supervisor SSO Active
SOLCL-CORE2-TI#show redund
SOLCL-CORE2-TI#show redundancy
Available system uptime = 42 weeks, 11 minutes
Configured Redundancy Mode = Stateful Switchover
Operating Redundancy Mode = Stateful Switchover
Uptime in current state = 42 weeks, 7 hours, 4 minutes
oftware (cat4500e-UNIVERSALK9-M), Version 03.03.00.SG RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Sun 15-Apr-12 08:06 by prod
BOOT = bootflash:cat4500e-universalk9.SPA.03.03.00.SG.151-1.SG.bin,1;
Configuration register = 0x2101
Peer (slot: 4) information is not available because it is in 'UNKNOWN' state
Reza Sharifi
In order for SSO to work correctly, the IOS versions in all Sups must be the same.
Also, one of your switches is configured as 0x2101, please change it to 0x2102 and reload the sup.
