Stackwise-Virtual in c9500-40x-E is not supported ???
Sharath Karpur
Hello All,
I am trying to configure c9500-40x-E pair with IOS 16.08.1a for stackwise but I do not see the command line is supported. Could some one help me if i am missing some details and fix.
Sharath Karpur
6 Replies 6
balaji.bandi
C9500 supports now Stackwise-Virtual as per the below document, depends on license you have, i believe you need network advantage to achieve this. what kind of License you have ?
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9500/software/release/16-8/release_notes/ol-16-8-9500.html
Also consider looking Limitations and restrictions before deploying in live environment.
BB
Hello Balaji,
my box is for Network Essential
Switch#sh license right-to-use
Slot# License Name Type Count Period left
1 network-essentials Permanent N/A Lifetime
1 dna-essentials Subscription N/A CSSM Managed
License Level on Reboot: network-essentials+dna-essentials Subscription
Yes firmware release notes says its supports but partially not
Sharath
As per documentation you need network advantage.
BB
I did some more testing and could observe that 16.6.1 code is supporting stackwise-virtual (stacking).
my question would be now:
why it is not supporting in latest release ? any know bugs ?
Hello all,
Does the Dual active Detection is connect and configured, but i see interface is not connected is this the normal behavior  ?
Switch#sh int status | in Te1/0/38
Te1/0/38 notconnect 4094 full 10G SFP-10GBase-SR
Sharath
Looks like you are mixing too many questions in one thread, so we are confused to answer.
BB
