HSRP Failove Issue
bh
In HSRP we are facing some issue in implementation.
As for the network brief, Network Diagram and configuration of both the Cisco 3560 switch is attached here. There are two Cisco 500 switches at the edge, in these switches we have just given Management IP on the Vlan 1, there is no other Vlan configured, STP is enable on the switch there is no other configuration on the switch.
Description of Attached
• For Vlan 1 we have Cisco 3560 Switch - 1 assigned high HSRP priority.
• For Vlan 2 we have Cisco 3560 Switch - 2 assigned high HSRP priority.
• INTERVLAN routing is enabled.
Now as we have done the configuration on the switches as attached and mention above.
STP is seems working, as in normal condition it is blocking the port. Now as when we remove the cable from gig 0/22 from Cisco 3560 Switch - 2 (which was in forwarding mode in normal condition) the failover is not working, the network 10.10.0.0/24 becomes unreachable.
So are there any configuration changes required. Or any other think need to be look into this scenario.
10 Replies 10
Dipesh Patel
Level 2
Level 2
hi,
interface Vlan1
ip address x.x.1.2 255.255.255.0
no ip redirects
no ip unreachables
standby 2 priority 125 preempt
standby 2 ip x.x.1.1
interface Vlan2
ip address x.x.2.2 255.255.255.0
no ip redirects
no ip unreachables
standby 2 priority 115
standby 2 ip x.x.2.1
interface Vlan1
ip address x.x.1.3 255.255.255.0
no ip redirects
no ip unreachables
interface Vlan2
ip address x.x.2.3 255.255.255.0
no ip redirects
no ip unreachables
This type of Configuration should be.
Can you paste the configuration? Than Exact fault can be detected.
Dipesh.
Marwan ALshawi
what is ur STP config ?
glen.grant
All your client workstations have their defalt gateway pointed the hsrp virtual ip ??? What state is hsrp in when you pull the cable , does it show switch 1 then as the hsrp active side ?
don't know much about the cat 500 , have never used them so can't help you there. Is the trunk between the cat 500 and switch 1 working correctly?
There is no configuration done for STP, it is in default....
There is no change in the HSRP state when i pull the cable....
Hey i have a point on this ?????
when i pulled out my cable out port at the edge switch will remain up as it is connected to FOT (Media Convertor) so the MAC table is not flushing out and due to this my frames are forwarded to the wrong port
Is it possible that due to this i have to wait 5 to 7 minutes to see the network reachable
in my testing i have given maximum 3 minutes to see the network go up ......
Bhargav
Hi Bhargav. I think your problem is the media converter. You'll end up with a UDLD situation here -- one side of the link is down (the edge switch that you disconnected the cable from) and the other side is still up.
I believe the problem is because the switches cannot 'see' past the media converter -- which is really just a two port repeater with different media types.
I use media converters as well, and have to set the speed/duplex settings manually because the switches I use (3550s) will not negotiate speed/duplex over the media converters.
BTW, I'm assuming the 'cable' you describe disconnecting is the RJ45 copper ethernet, not the fiber optic cable -- although I think you'll still have the same HSRP problem either way.
I'm not positive about this being the problem, but I suggest trying this config without the media converters.
Good luck.
Darren.
Hi Dipesh,
Here is the cut out of configration...............
Bhargav
Hi, Darren
As we have site far way and the sites are connected with fiber as i have mentioned and the older switches does not have fiber port i can not terminate them directally.
Bhargav
Hi Bhargav. I understand what you mean ... I have the same problem on my campus as well. I guess what I'm saying is that because you are using media converters, you may not be able to solve this if these media converters are the root problem.
I hope I'm wrong in this case, but it seems like your switches believe the link is still up/good because the switch cannot 'see' past the media converter.
Let me know if I'm wrong! :)
There may be a way around this problem that I'm not aware of... I'd like to know how to fix it too!
Darren.
Hi Bhargav,
Sorry Yaar,
I was out side the site and can't reply.
Ya, Darren is right ....
Here you say that if you unplug cable from gi0/22 Media Converter Eth Port will be down but the Fiber Port will be up and hence at the end other side SWitch - 2 will remain UP ( In the case if Fibercable between media converter is cut the same senario will be ). Now This SW STP will not changes as it can't find any changes in topology hence Gi0/2 of SWitch will remain forwarding mode but actually is not. That may be the problem.
In this situation you check the spanning tree detail on Swtich 2 that which port is in forwading mode.
Dipesh,
Hi Dipesh,
A query is that although the port is in forwarding mode the MAC table will not flush after 5 min ?????
And the new forwarding port will start learning MAC and start Forwarding from that port ???? Does this will be possible ???
Bhargav
