HSRP / Failover on CSS1100 Load balancer
bapatsubodh
We have two css 11500 series , we need to configure in HSRP mode. So that if one fails second will automatically take over. Like PIX is it required to be configured like active and failover mode with stateful or stateless mode of failover. Do we need seperate licenses for such configuration similar to PIX.
( In our case VIP adress and server IP address are on the same Subnet , source and Dest NAT is done using server groups in CSS).
Any link on cisco.com or working example configuration guidelines are highly appreciable.
Thanx in advance
Subodh
rais
Level 7
Level 7
Here is the URL for the configuration for the Configuring VIP and Virtual IP Interface Redundancy follow the configuration guide which may help you
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/css11500series/v8.20_v8.10/configuration/redundancy/guide/VIPRedun.html
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/css11500series/v8.20_v8.10/configuration/redundancy/guide/ASR.html
Configuring Box to box redundancy:
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/css11500series/v8.20_v8.10/configuration/redundancy/guide/Redndncy.html
CSS 11500 Active-Active Stateful Failover ASR in One-Armed Mode Configuration Example
http://www.cisco.com/en/US/products/hw/contnetw/ps792/products_configuration_example09186a00802206a3.shtml
Box-to-Box Redundancy on the CSS 11xxx Configuration Example - Ciscowiki
http://supportwiki.cisco.com/ViewWiki/index.php/Box-to-Box_Redundancy_on_the_CSS_11xxx_Configuration_Example
Kindly find full range of configuration examples on CSS here :
Cisco CSS 11500 Series Content Services Switches
Configuration Examples and TechNotes
http://www.cisco.com/en/US/products/hw/contnetw/ps792/prod_configuration_examples_list.html
http://supportwiki.cisco.com/ViewWiki/index.php/Category:Cisco_CSS_11500_Series_Content_Services_Switches
Kindly see URL given below for my other articles
http://boardreader.com/fp/Cisco_Systems_Networking_Profe_309110/Application_Networking_543840.html#hot_threads
If possible plz rate sothat I can be helpful to other people also as it will enhance my credibility.
Sachinga.hcl
