HSRP hardware limitation on catalyst 4500-X
rherve
Is there anyone who could give me the hardware limit on the maximum number of HSRP group that you can use simultaneously on a Catalyst 4500-x?
Is it 256 ?
If someone can do the test? Unfortunately I don't have a 4500-x to make the test
Regards.
branfarm1
Level 4
Level 4
Still 256 ---
4500X-1(config-if)#standby ?
  <0-255>         group number
  authentication  Authentication
  bfd             Enable HSRP BFD
  delay           HSRP initialisation delay
  follow          Name of HSRP group to follow
  ip              Enable HSRP IPv4 and set the virtual IP address
  ipv6            Enable HSRP IPv6
  mac-address     Virtual MAC address
  mac-refresh     Refresh MAC cache on switch by periodically sending packet
                  from virtual mac address
  name            Redundancy name string
  preempt         Overthrow lower priority Active routers
  priority        Priority level
  redirect        Configure sending of ICMP Redirect messages with an HSRP
                  virtual IP address as the gateway IP address
  timers          Hello and hold timers
  track           Priority tracking
  use-bia         HSRP uses interface's burned in address
  version         HSRP version
Can you clarify what you mean "hardware limit on the maximum number of HSRP group"?
The limit of 256 is an HSRP version 1 protocol limit with respect to the range that the HSRP group can be set to. If you look at RFC 2281 Cisco HSRP, you'll see this specified in section 5.1:
    Group:   1 octet
      This field identifies the standby group.  For Token Ring, values
      between 0 and 2 inclusive are valid.  For other media values
      between 0 and 255 inclusive are valid.
If you use HSRP version 2 the HSRP group number range is 0-4095 and once you've specified standby version 2 within the interface vlan context then the extended range can be seen.
So if you want to use more than 256 HSRP groups on a router then HSRP version 2 is the way to go. The only thing to be mindful of then is how that number of groups may affect the CPU utilisation of the router.
Thank you for your answers, but I am not sure because I had test these commands on a 3750X and I also <0-255> group number.
example:
3750x(config-if)#standby ?
This means that I can configure 256 id en hsrp version 1 from 0 et 255.
But when I create more than 32 vlans configured with HSRP protocol then I reach the maximum hardware limit.
I receive the following message:
3750x(config-if)#standby ip 10.10.34.254
%Platform already has maximum FHRP groups configured
The real test would be configured on the 4500-X up to 256 vlans with the HSRP config for these 256 vlans to see if the message is identical to 3750x? If the hardware limit are reach
Can you test it for me please ?
I'd rather have found some official documentation from Cisco that stated the limit they support, but in the absence of that I've tested it and it would seem there's no obvious limit as you found with the Catalyst 3750.
In the output of the show version you can see there are now 256 Virtual Ethernet Interfaces created, the show standby internal summary shows 247 configured interfaces and there's also a snip of the show standby brief.
There are only 247 interfaces seen in show standby internal summary as I already had some interfaces with GLBP running so couldn't configure those interfaces with HSRP. Note also that they show as INIT as I only configured one device.
4516x-1#sh ver
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSALK9-M), Version 03.05.00.E RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Tue 27-Aug-13 14:56 by prod_rel_team
cisco WS-C4500X-16 (MPC8572) processor (revision 4) with 4194304K bytes of physical memory.
Processor board ID JAE164800HF
MPC8572 CPU at 1.5GHz, Cisco Catalyst 4500X
Last reset from Reload
256 Virtual Ethernet interfaces
16 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
4516x-1#sh standby internal summary
Configured     0        247      0        0        0        1        1
Learnt         0        0        0        0        0        0        0
4516x-1#sh stand brief
                     P indicates configured to preempt.
Interface   Grp  Pri P State   Active          Standby         Virtual IP
Vl2         2    100   Init    unknown         unknown         3.3.2.1
Vl3         3    100   Init    unknown         unknown         3.3.3.1
Vl4         4    100   Init    unknown         unknown         3.3.4.1
Vl5         5    100   Init    unknown         unknown         3.3.5.1
Vl6         6    100   Init    unknown         unknown         3.3.6.1
Vl250       250  100   Init    unknown         unknown         3.3.250.1
Vl251       251  100   Init    unknown         unknown         3.3.251.1
Vl252       252  100   Init    unknown         unknown         3.3.252.1
Vl253       253  100   Init    unknown         unknown         3.3.253.1
Vl254       254  100   Init    unknown         unknown         3.3.254.1
Vl255       255  100   Init    unknown         unknown         3.3.255.1
