HSRP lab
whiteford
I want to configure HSRP in my lab, I only have 2 x C2620 routers and only have 1 x Ethernet and 2 x WIC on each, is it possible to create an HSPR environment?
If not how would a simple config look?
Joseph W. Doherty
I believe so. Just configure HSRP on each router's Ethernet interface. Insure two routers' Ethernet interfaces are connected (directly, hub or switch).
adamclarkuk_2
Level 4
Level 4
As suggested, link the two routers up directly via a crossover cable or via a hub/switch with a straight cable.
An example config for HSRP follows :
Router 1
Ethernet 0/0
ip address 192.168.1.2 255.255.255.0
standby 100 ip 192.168.1.1
standby 100 preempt
Router 2
ip address 192.168.1.3 255.255.255.0
standby 100 priority 150
standby 100 preempt
Hello Andy,
to make a meaningful test an hub or switch is needed so that you can add at least a PC client to the vlan to be able to test what happens when the active router changes.
Hope to help
Giuseppe
