06-13-2007 01:42 AM - edited 03-05-2019 04:40 PM
Is it possible to run HSRP between 2 Catalyst 4500 switches if each switch has 2 route switch modules running HSRP internally?
06-13-2007 02:10 AM
As I know, you can run HSRP btw 2 4500, but the supervisors on the same chasis is not possible to run HSRP.
Check this out.
http://www.cisco.com/warp/public/473/177.html#topic4
Log in to Community
