HSRP not working
we have two cisco routers , one is 1941 and 1841
they're both connecte dto BB switch
yesterday we disconnected LAN interface Gi0/1 on the active router (1941) and there was no failover .
please advise why failover didn't happened
here is my config:
1941 router:
interface GigabitEthernet0/1
 description to LAN
 ip address 172.16.55.2 255.255.255.248
 ip helper-address x.x.x.3
 ip helper-address x.x.x.8
 ip flow ingress
 ip flow egress
 standby 0 ip 172.16.55.1
 standby 0 priority 120
 standby 0 preempt
 standby 0 track 1 decrement 50
 load-interval 30
 duplex auto
 speed auto
 hold-queue 8000 in
 hold-queue 8000 out
end
#sh standby
GigabitEthernet0/1 - Group 0
  State is Active
    25 state changes, last state change 2d23h
  Virtual IP address is 172.16.55.1
  Active virtual MAC address is 0000.xxxx.ac00
    Local virtual MAC address is 0000.xxxx.ac00 (v1 default)
  Hello time 3 sec, hold time 10 sec
    Next hello sent in 1.472 secs
  Preemption enabled
  Active router is local
  Standby router is 172.16.55.3, priority 110 (expires in 9.216 sec)
  Priority 120 (configured 120)
    Track object 1 state Up decrement 50
  Group name is "hsrp-Gi0/1-0" (default)
1841 router:
#sh run int FastEthernet0/1
interface FastEthernet0/1
 description #To Lan#
 ip address 172.16.55.3 255.255.255.248
 ip flow ingress
 ip flow egress
 duplex auto
 speed auto
 standby 0 priority 110
 standby 0 preempt
 standby 0 track 1 decrement 10
end
#sh standby
FastEthernet0/1 - Group 0
  State is Standby
    Next hello sent in 2.740 secs
  Preemption enabled
  Active router is 172.16.55.2, priority 120 (expires in 7.408 sec)
  Standby router is local
  Priority 110 (configured 110)
    Track object 1 state Up decrement 10
  Group name is "hsrp-Fa0/1-0" (default)
10 Replies 10
Mark Malone
Your hsrp is configured correctly and shows there was a state change 2 days ago which would say that it works ok  , did you get any logs when you pulled the link on the router or switch connected ?  did you check the STP status of the g0/1 on the switch connection to the router when you pulled the link
On the HP backbone switch i can learn all three ip addresses:
  172.16.55.1      00xxxx-07ac00     dynamic B1
  172.16.55.2      bcxxxx-487bc1     dynamic B1
  172.16.55.3      00xxxx-f903c1     dynamic D24
And on STP status both interfaces connected to both routers are in Forwarding state:
  B1     100/1000T | 20000     128  Forwarding   | 2cxxxx-344e00 2    Yes Yes
  D24    100/1000T | 200000    128  Forwarding   | 2cxxxx-344e00 2    Yes Yes
Yes that's the issue its all reset now back working and showing as correct so finding out what happened will be very difficult to know as it was a real time issue , you need to pull the link again and debug the HSRP to see what exactly is happening if its not working still on failover
can the clock on both router couse a problem to HSRP not to work if both clocks are not same ?
No absolutely not but it won't help your logging having times incorrect , HSRP is an independent protocol it runs without a requirement from any other service including clocks , when HSRP fails in failover 9 times out of 10 its a layer 1 or 2 issue
today we tested again the HSRP and the HSRP worked fine . but the network still was down . the was no ping to google
we noticed that when we disconnected the cable from Gi0/1 the standby router bacame active
in traceroute from the PC we reached until the active router but it stop there . the next hop hirarchy layer is two cisco router connected to each other via EIGRP.
which i think that the next hop router is still forwarding the LAN network to the other one !
why this is happening ?
I attached photo almost explain what is happening ..
Is there a reason your using EIGRP between the 2 routers if HSRP is acting as the failover mechanism between the 2 routers  ?
Its difficult to say why without seeing your routing setup as now the problem is layer 3 rather than the HSRP , if you shut the EIGRP link both sides does it work ok or try set a very high EIGRP delay so its not a preferred path
no its not like that
as you can see in the topology i attached before , the two cisco routers acting in HSRP are in the distribution layer . in the core layer we have another two cisco routers acting in EIGRP two share routes between eath other .
It is a little confusing looking at your drawing.
Is it the 10.10.66.0/24 subnet that loses connectivity to the Internet? If so, are both routers advertising it in their EIGRP? (more importantly the 1841 when active)
we opened a maintinance windows today morning and we resolved the with one of our cisco experts
just wanted to share with you guys which configurations we needed in order to fix the problem :
track 2 interface GigabitEthernet0/1 line-protocol
ip route 10.10.xx.0 255.255.255.0 172.16.55.6 track 2
(xx= all our LAN networks)
router eigrp 1
 network 172.16.206.0 0.0.0.7
 redistribute static
 redistribute connected
 passive-interface GigabitEthernet0/1
