HSRP on Nexus (first time)
Andrew White
Level 2
Level 2
I'm just having a play with 2 Nexus switches (7.3) as I've not used this before.
Currently I have 1 Nexus setup with 1 laptop connected on an access port and I've configured VLAN30 as an an HSRP and I eventually what to use HSRP between the 2 Nexus switches for our user VLANs as I will be connecting some Cisco 2960x L2 switches to these as trunks.
I added the below config to 1 switch and the laptop can ping the physical IP for VLAN 30 (.252) but not the HSRP virtual IP (.254).
Config:
vlan 30
name USER30
vlan configuration 30
interface Vlan1
interface Vlan30
no shutdown
no ip redirects
ip address 172.18.30.252/24
hsrp 30
preempt delay minimum 60
priority 115
timers msec 250 msec 750
ip 172.18.30.254
HSRP is up for VLAN 30 (just 1 switch atm)
Vlan30 - Group 30 (HSRP-V1) (IPv4)
Local state is Active, priority 115 (Cfged 115), may preempt
Forwarding threshold(for vPC), lower: 1 upper: 115
Preemption Delay (Seconds) Minimum:60
Hellotime 250 msec, holdtime 750 msec
Next hello sent in 0.041000 sec(s)
Virtual IP address is 172.18.30.254 (Cfged)
Active router is local
Standby router is unknown
Authentication text "cisco"
Virtual mac address is 0000.0c07.ac1e (Default MAC)
2 state changes, last state change 00:03:02
IP redundancy name is hsrp-Vlan30-30 (default)
Form the switch the ping works to the laptop:
switch# ping 172.18.30.10
PING 172.18.30.10 (172.18.30.10): 56 data bytes
64 bytes from 172.18.30.10: icmp_seq=0 ttl=63 time=9.017 ms
64 bytes from 172.18.30.10: icmp_seq=1 ttl=63 time=1.952 ms
However the Laptop can only ping physical IP (172.18.30.252) and not the HSRP (172.18.30.254).
Am I missing something?  I will connect the 2nd switch as part of the HSRP, but I should still be able to ping the virtual address.
12 Replies 12
which Nexus is this on ? Have you gobally enabled the HSRP feature:
Nexus(config)#feature hsrp
Yes the feature is turned on.
I will try version 2 and let you know
Reza Sharifi
Not that this should make any difference but can you configure hsrp version 2 and test again?
hsrp version 2
hsrp 30
priority 115
ip 172.18.30.254
balaji.bandi
Below example configuration : we would like to know how they are connected each other.
If you building 2 nexus you need to build with vPC and allowed the requeired VLAN in vPC.
HSRP
N7K1
feature hsrp
interface Vlan9
description MGMT-NET HSRP
no shutdown
no ip redirects
ip address 10.10.9.2/24
no ipv6 redirects
hsrp 9
preempt
priority 150
timers 1 3
ip 10.10.9.1
end
N7K2
feature hsrp
interface Vlan9
no shutdown
no ip redirects
ip address 10.10.9.3/24
no ipv6 redirects
hsrp 9
preempt
priority 130
timers 1 3
ip 10.10.9.1
end
You can verify show standby breif will show you HSRP working.
BB
I have not configure the vPC yet as the 2nd Nexus is not out of the box yet, but shouldn't the HSRP virtual IP still work?  It's as if the 2nd switch is down so I'm essentially in DR mode :)
Do you have a example on configuring the vPC?  Eventually I want to add a 3850 to both as portchannel but I think I need to add the vPC to it?  something like this:
interface port-channel10
  description Uplinkto3850
  switchport mode trunk
  switchport trunk native vlan 999
  switchport trunk allowed vlan 9,999
  spanning-tree port type normal
  speed 10000
  vpc 9
I guess something like this on the Nexus:?
here is config related to nexus and 3850, hope you have already have based vPC config between nexus 1 and nexus 2
Nexus 1
switchport trunk allowed vlan 9,900
vpc 10
no shutdown
interface Ethernet1/16
description to 3850
channel-group 10 mode active
no shutdown
Nexus 2
vpc 10
no shutdown
description to 3850
no shutdown
3850
interface Port-channel10
no shutdown
interface GigabitEthernet1/0/1
Description to Nexus 1
no shutdown
interface GigabitEthernet1/0/2
Description to Nexus 2
no shutdown
BB
Wow let me test this.
I see a vPC is basically an etherchannel for the Nexus am I right? It sort of makes them 1 logical switch and can help with no loops?
What is the reason to add the vPC to the port channel etc?
This i why you would use a VPC port-channel to your switches below , if there standalone and not FEXs which integrate like linecards you should use the VPC on Nexus side and standard PO config on switch side as they dont support VPC but can interact with it as balaji has shown above in sample configs
 A vPC provides the following benefits:
• Allows a single device to use a PortChannel across two upstream devices
• Eliminates Spanning Tree Protocol blocked ports
• Provides a loop-free topology
• Uses all available uplink bandwidth
• Provides fast convergence if either the link or a device fails
• Provides link-level resiliency
• Helps ensure high availability
yes that is correct, you can find sample information vpc deployment guides, if not let me know we can offer one for you.
let me know how it goes ?
BB
Thanks guys,
can you provide the base vPC config between the 2 nexus switches too, I’m not sure I’ve done it right?
thanks
here is cisco official guide.
https://www.cisco.com/c/en/us/products/collateral/switches/nexus-5000-series-switches/configuration_guide_c07-543563.html
if you still have difficulties let me know.
BB
Heres a working setup of my switches you could tweak easily to your own , 4 links between both nexus devices portchannel 1 for VPC peer link , then a heartbeat link as well over a vlan at l3 between both switches
You need a hearbeat incase VPC ever crashed so it can come back up
VPC Config
vpc domain 200
role priority 200
system-priority 150
peer-keepalive destination x.x.x.x source x.x.x.x
delay restore 90
interface mgmt0
description OOB.TRUSTED.SERVER
vrf member management
ip address x.x.x.x
interface Vlan3003
description VPC Heartbeat
vrf member heartbeat
ip address 10.1.1.1/30
interface Ethernet1/44
switchport access vlan 3003
logging event port link-status
description Peer_Link_To_xxxxxxxxx
no lacp suspend-individual
switchport trunk allowed vlan 2,10-11,17-18,20,28,31,33-34,36-39,48,50,64-65,70,72,74,76,78,80,90-96,102-103,105,107,400,1226,2224
spanning-tree port type network
speed 10000
vpc peer-link
interface Ethernet1/45
description Peer_Link_1_of_4_to_xxxxxxxxxx
channel-group 1 mode active
interface Ethernet1/46
description Peer_Link_2_of_4_to_xxxxxxxxx
interface Ethernet1/47
description Peer_Link_3_of_4_to_xxxxxxxxx
interface Ethernet1/48
description Peer_Link_4_of_4_to_xxxxxxxxxxx
vpc domain 200
role priority 150
system-priority 150
delay restore 90
interface mgmt0
ip address x.x.x.x/x
interface Vlan3003
ip address 10.1.1.2/30
