10-05-2020 06:39 AM
is WS-C2960X-24TS-L support HSRP ar can we create trunk between this switch using CAT 6 ?
Solved! Go to Solution.
10-05-2020 06:43 AM
Yes, HSRP is supported, and you can use a copper port to trunk between the switches.
Hot Standby Routing Protocol (HSRP) and Virtual Router Redundancy Protocol (VRRP) provide dynamic load balancing and failover for routed links.
10-05-2020 06:43 AM
10-05-2020 06:43 AM
