08-17-2020 06:32 AM
hi everyone,
i have cisco catalyst 3650-24ts-s switch i wanted to create a redundancy using HSRP or VRRP.
but i am confuse which protocol to use ? are this two protocol supported in this switch ?
Solved! Go to Solution.
08-18-2020 05:12 AM
sure ( make sure the VLAN/SVI streched across device so they can see each other).
here is the guide :
08-17-2020 06:41 AM
Hello @pritamjitbiswas ,
according to the following thread both protocols are supported but you cannot use both in different Vlans
see
https://community.cisco.com/t5/small-business-switches/vrrp-hsrp-cisco-3560/m-p/2919870
Either you use HSRP everywhere exor you use VRRP everywhere.
Hope to help
Giuseppe
08-17-2020 07:32 AM
08-17-2020 08:57 AM
I prefer to have HSRP here if only cisco devices involved. ( again your choice).
08-18-2020 04:38 AM
we have multiple VLAN . is HSRP can run on VLAN interface instead of physical interface
08-18-2020 05:12 AM
here is the guide :
