HSRP preempt-question
siddhartham
Level 9
Level 9
We have the below config on our distribution switches.Dist-B is the Active switch for VLAN117 and I am tracking the uplink on the Dist-B so the priority will go down by 15 if the uplink (g1/1) goes down.
Dist-A
interface Vlan117
ip address 10.5.117.2 255.255.255.0
ip helper-address 10.0.1.3
ip helper-address 10.0.1.9
standby 117 ip 10.5.117.1
Dist-B
interface Vlan117
ip address 10.5.117.3 255.255.255.0
standby 117 priority 110
standby 117 preempt delay minimum 180
standby 117 track 1 decrement 15
We had an issue with our SFP and g1/1 on thr DIST-B went down as specified in the tracking statement the priority on dist-B became 95 but the state change didn't happen. Dist-B with priority 95 acted as the HSRP active switch and dist-A switch priority 100 acted as a standby switch.Why didn't switch with higher priority, disr-A, took over the active role. Do I have to configure preempt command on dist-A for it take over role from a low priority switch?
Dist-A
Vlan117 - Group 117
  State is Standby
    1 state change, last state change 24w2d
  Virtual IP address is 10.5.117.1
  Active virtual MAC address is 0000.0c07.ac75
    Local virtual MAC address is 0000.0c07.ac75 (v1 default)
  Hello time 3 sec, hold time 10 sec
    Next hello sent in 1.424 secs
  Preemption disabled
  Active router is 10.5.117.3, priority 95 (expires in 9.232 sec)
  Standby router is local
  Priority 100 (default 100)
  Group name is "hsrp-Vl117-117" (default)
Dist-A
Vlan117 - Group 117
  State is Active
    2 state changes, last state change 51w2d
    Next hello sent in 1.584 secs
  Preemption enabled, delay min 180 secs
  Active router is local
  Standby router is 10.5.117.2, priority 100 (expires in 9.104 sec)
  Priority 95 (configured 110)
    Track interface GigabitEthernet1/1 state Down decrement 15
Siddhartha
Siddhartha
2 Accepted Solutions
cadet alain
yes you have to configure preemption on the switch A for it to became the active device.
Alain
Gregory Snipes
Level 11
Level 11
Yes, you need to configure "standby 117 preempt" on both of these devices.
cadet alain
Alain
Thanks both of you.
Siddhartha
Siddhartha
Gregory Snipes
Level 11
Level 11
