HSRP Question
nojpt
Level 3
Level 3
Sorry if this seemed like a newbie question...
Is it normal for my standby router to have a bigger outgoing traffic than my active router on a HSRP group?
Richard Burts
Jonathan
HSRP affects traffic from the end stations in the subnet/VLAN to the active router. So the active router should probably have higher input than the standby router. But then the routers forward traffic to its destination and the destination sends responses back to the source. Depending on how routing is set up, it is quite possible that more of the response traffic will be sent through the standby router and that the standby router will have higher output into the subnet/VLAN.
Rick
Rick
Richard Burts
Jonathan
Rick
Rick
Thank Rick.
4rmorris
Level 5
Level 5
Maybe, if your standby router is (for instance) the first router on the HSRP subnet that traffic outside the subnet comes to (from the WAN, say). Please post some kind of diagram or config output, and we can say for sure.
Ryan
Jonathan
I am glad that my response was helpful. Thank you for using the rating system to indicate that your question was resolved (and thanks for the rating). It makes the forum more useful when people can read a question and can know that a response did resolve the question.
The forum is an excellent place to learn about Cisco networking. I encourage you to continue your participation in the forum.
Rick
Rick
