ā02-27-2011 02:01 AM - edited ā03-06-2019 03:47 PM
Can anyone point to the the maximum SVI interfaces supported on the following platforms:
Cat4500 sup6e/sup7
Cat6500 sup 720 3B
Roni
ā02-27-2011 03:45 AM
Well I looked but couldn't find a hard answer to this. It depends on the memory as well in your supervisor. Each SVI uses a little memory so it depends on other processes, configuration etc as to how many it will support at any one time.
HTH,
Ian
ā02-27-2011 08:11 AM
Thanks Ian, The thing is that for some switches (I.E - ME3400) there is a specific limitation refered in the configuration guide, not connected to the memory of the switch, I cannot find in the release notes or the configuration guide the limitation to the platforms I mentioned in my post.
BR,
Roni
ā02-28-2011 12:25 AM
The command reference still says the same for this model:
Although the switch supports a total of 1005 VLANs (and SVIs), the interrelationship between the number of SVIs and routed ports and the number of other features being configured might impact CPU performance because of hardware limitations. See the "Configuring Layer 3 Interfaces" section for information about what happens when hardware resource limitations are reached.
Sorry I can't find anything more.
Ian
