HSRP unknown Peer
macazarpros
Community Member
My router failed over and i havent figured out why.. they are using HSRP.. please assist... both are showing active with an unknown peer.. and the backup is being accessed when using telnet to the virtual IP..please assist.. see config several vlans are configured but i'll put the information for one.. both routers are connected to a stacked switch 3760G and the port connected to router 1 is flapping up and down. the cable is good connecting the router to the switch
Primary router
GigabitEthernet0/2.10 - Group 10
  State is Active
    1 state change, last state change 3d16h
  Virtual IP address is 2.10.1.23
  Active virtual MAC address is 0000.0c07.ac0a
    Local virtual MAC address is 0000.0c07.ac0a (v1 default)
  Hello time 1 sec, hold time 3 sec
    Next hello sent in 0.320 secs
  Authentication MD5, key-string
  Preemption enabled
  Active router is local
  Standby router is unknown
  Priority 255 (configured 255)
  Group name is "hsrp-Gi0/2.10-10" (default)
secondary router
HSB_RT02#sh standby
  State is Active
    136 state changes, last state change 11w3d
    Next hello sent in 0.736 secs
  Preemption enabled
  Priority 254 (configured 254)
debug on router 1
og Buffer (8192 bytes):
Grp 45 Active: h/Hello rcvd from lower pri Active router (254/172.31.255.28)
*Jun  8 23:24:03.893: HSRP: Gi0/2.450 Grp 45 Coup   out 172.31.255.29 Active  pri 255 vIP 172.31.255.30
*Jun  8 23:24:03.893: HSRP: Gi0/2.450 Grp 45 Hello  out 172.31.255.29 Active  pri 255 vIP 172.31.255.30
*Jun  8 23:24:03.901: HSRP: Gi0/2.10 Grp 10 Hello  out 2.10.1.250 Active  pri 255 vIP 2.10.1.23
*Jun  8 23:24:04.037: HSRP: Gi0/2.10 Grp 10 Hello  in  2.10.1.251 Active  pri 254 vIP 2.10.1.23
*Jun  8 23:24:04.037: HSRP: Gi0/2.10 Grp 10 Active: h/Hello rcvd from lower pri Active router (254/2.10.1.251)
*Jun  8 23:24:04.037: HSRP: Gi0/2.10 Grp 10 Coup   out 2.10.1.250 Active  pri 255 vIP 2.10.1.23
*Jun  8 23:24:04.037: HSRP: Gi0/2.10 Grp 10 Hello  out 2.10.1.250 Active  pri 255 vIP 2.10.1.23
*Jun  8 23:24:04.229: HSRP: Gi0/2.175 Grp 175 Hello  in  192.168.175.251 Active  pri 254 vIP 192.168.175.1
*Jun  8 23:24:04.229: HSRP: Gi0/2.175 Grp 175 Active: h/Hello rcvd from lower pri Active router (254/192.168.175.251)
*Jun  8 23:24:04.229: HSRP: Gi0/2.175 Grp 175 Coup   out 192.168.175.250 Active  pri 255 vIP 192.168.175.1
*Jun  8 23:24:04.229: HSRP: Gi0/2.175 Grp 175 Hello  out 192.168.175.250 Active  pri 255 vIP 192.168.175.1
*Jun  8 23:24:04.469: HSRP: Gi0/2.20 Grp 20 Hello  in  192.168.2.251 Active  pri 254 vIP 192.168.2.1
*Jun  8 23:24:04.469: HSRP: Gi0/2.20 Grp 20 Active: h/Hello rcvd from lower pri Active router (254/192.168.2.251)
*Jun  8 23:24:04.469: HSRP: Gi0/2.20 Grp 20 Coup   out 192.168.2.250 Active  pri 255 vIP 192.168.2.1
*Jun  8 23:24:04.469: HSRP: Gi0/2.20 Grp 20 Hello  out 192.168.2.250 Active  pri 255 vIP 192.168.2.1
*Jun  8 23:24:04.553: HSRP: Gi0/2.176 Grp 176 Hello  out 192.168.176.250 Active  pri 255 vIP 192.168.176.1
*Jun  8 23:24:04.645: HSRP: Gi0/2.176 Grp 176 Hello  in  192.168.176.251 Active  pri 254 vIP 192.168.176.1
*Jun  8 23:24:04.645: HSRP: Gi0/2.176 Grp 176 Active: h/Hello rcvd from lower pri Active router (254/192.168.176.251)
*Jun  8 23:24:04.645: HSRP: Gi0/2.176 Grp 176 Coup   out 192.168.176.250 Active  pri 255 vIP 192.168.176.1
*Jun  8 23:24:04.645: HSRP: Gi0/2.176 Grp 176 Hello  out 192.168.176.250 Active  pri 255 vIP 192.168.176.1
spanning tree on the switch shows both ports are fowarding
8 Replies 8
David_Che
Level 5
Level 5
Can you show the backup router log like on the primary? I suspect that unidirectional connection cause one direction packet flow okay, but not okay in the another direction. In this case, primary router can send&receive HSRP packet, but if the backup can not receive primary's HSRP hello, it would suppose the primary has been down, so it will act as the active.
if UDLD has been configured, which can avoid such issue.
yes david.. the primary router appears to be bad.. visual inspection shows all the router ports blinking even if no cable is plugged in
InayathUlla Sharieff
Agree with David, When HSRP Hello's are missed between the 2 devices you will end up in Active Active scenario.
You are now in ACtive/ACtive scenario. Were there is no communication between the switches.
1- Can you check logging the device and pinging between each other?
2- I mean to say ping the same subnet ip address between each other?
3- Can you check the cable connected to it is working good? If possible try changing the cable and ports.
4- Check the CPU on the box.
Inayath
thanks for you response.. the cable is good.. but cant ping the primary... upon closer inspection all the ports on the router a blinking even if no cable is connected... so it appears the router itself is bad... i got the commands pasted above from the console....
Next Actoin:-
What device is this?
If this is modular Switch then try to re-seat the card and check?
If non-modular Switch try rebooting it once and check the LED.
Once the LED are stable (Mean its on off the port which has the link) then
Try to change the cable and port and update us the result.
Inayath
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.0(1)M4,
http://images10.newegg.com/ProductImage/A1K0_1_2014120394233814.j
replaced the router.. got the got the config via usb.. since the ports dont work... man i didnt now these usb ports work
Charles Hill
What is the router model and IOS?
May not be relative, but throwing it out there just in case.
Bug CSCeb36935 references a router port flapping, which results in active active state.
ine protocol between 7200 and switch is flapping so both router are in active state.
Workaround:
Workaround
* Ensure that there are no packet storms on the network (IPX is prone to do this).
* Changing the duplex setting of the switch. Try setting it to "auto".
* Configure "set spantree portfast enable" on the switch ports
Hope this helps,
Please rate helpful posts.
Thanks.
