HSRP with Vlan Maps
ciscona728
I was tasked to filter traffic on my network which consists of the following:
2 x Distros and a bunch of access switches.
I'm running HSRP on my vlans which works great but I have to filter outbound traffic from accessing certain things.  For example I would allow my local network to talk to another network then deny any any.  The issue exists when I apply my vlan access-map to a particular vlan.  For whatever reason HSRP stops working and both svi's on the two distros become active.  I tried vlan access maps and I've tried to apply the acl directly to the svi with the same results.
My config looks like the following
SW1
int vlan 10
ip add 192.168.1.2 255.255.255.0
standby 10 ip 192.168.1.1
standby 10 preempt
standby 10 priority 110
ip access-list extended vlan_filter
permit ip 192.168.1.0 0.0.0.255 172.16.0.0 0.0.255.255
permit ip 192.168.1.0 0.0.0.255 10.1.10.0 0.0.0.255
deny ip any any
vlan access-map Filter
  match ip address vlan_filter
  action forward
vlan filter Filter vlan-list 10
SW2
int vlan 10
ip add 192.168.1.3 255.255.255.0
standby 10 preempt
deny ip any any
   action forward
When applied that config to both switches and HSRP doesn't work at all.  If anyone has any suggestions please let me know.
Thanks in advance
Shashank Singh
It seems that the HSRP hellos are being blocked by the ACLs. HSRP hellos are sent on multicast address 224.0.0.2 and seem to be blocked by the deny statement in the ACL.
Try adding "permit ip any 224.0.0.2 0.0.0.0" as a statement in the ACL applied on the SVI to permit hellos between the HSRP peers.
Hope this helps,
Shashank
Please rate if you found the content useful
Shashank Singh
Hope this helps,
Shashank
Thanks Shashank that worked like a charm.
Thanks for the update. glad that it worked for you
Cheers!
Shashank
