HSRP with vPC
mohankumarm
Just want to check if you can use the burned-in MAC option on HSRP on VLAN interfaces in the current NX-OS version 6.x. testing shows that nothing seems to break during failover if this option is configured .
Thanks and Regards.
4 Accepted Solutions
Reza Sharifi
Hi Mohan,
This issue can only happns if you are using IPv6.
Packet Forwarding in a vPC with a HSRP V6 Group
In a vPC, packets that are forwarded through an HSRP virtual IP address (VIP) or virtual MAC address (VMAC) might fail. This situation can occur if a VLAN that is in a vPC has a HSRP V6 group and has the use-bia option enabled on an interface. Layer 3 traffic will be disrupted and packets might not reach the VIP. Removing the use-bia option from the interface in the vPC should correct this issue.
http://www.cisco.com/en/US/docs/switches/datacenter/sw/5_x/nx-os/release/notes/51_nx-os_release_note.html
Hi Mohan,
I would just go with traditional virtual MAC which is default and no need for an additional command. I really could not find what benefit this command provides.
Just my opinion.
Reza
Hi Mohan,
With traditional, there is no need to configure any mac address at all.  It is all done for you when you create your HSRP group.  Make sure to use HSRP version 2, as it provides the benefit of having the same vlan id matching your HSRP group because ver 2 supports up to 4094 groups.  I think, ver 1 is only up to 255.
So, it is nice and convenient to have for example vlan 425 and HSRP group 425.  You couldn't do this with ver 1 since the max number of HSRP group is 255. You also want to make sure what ever device is your primary vPC to be the active HSRP and the secondary vPC to be the backup HSRP.
Reza
Here is sample config of HSRP on your primary vPC
interface Vlan517
  ip address 192.xx.xx.67/27
  hsrp version 2
  hsrp 517
  hsrp version 2
  priority 110
   ip 192.xx.xx.65
  no shutdown
Reza
13 Replies 13
InayathUlla Sharieff
Hi Mohan,
To configure HSRP to use the burned-in MAC address of the interface for the virtual MAC address, use the following command in interface configuration mode:
Command
Purpose
hsrp use-bia[scope interface]
Example:
switch(config-if)# hsrp use-bia
Ref;http://www.cisco.com/en/US/docs/switches/datacenter/sw/5_x/nx-os/unicast/configuration/guide/l3_hsrp.html
Inayath
*Plz rate all usefull posts.
Hi Inayath,
Thanks very much indeed, but is there any caveat when you use this is the question now..which according to Reza is a bug for v6 HSRP groups.
Thanks and Regards
Mohan
Reza Sharifi
Hi Mohan,
I have never used the use-bia command, but Is there a reason for not using the virtual mac address?
Reza
Hi Reza,
The thought process here to use this command was because the layer 2 uplinks to the core will have two forwarding entries always in the mac table if "use-bia" is used  and also if you are using special servers like NetApp, which need mac address sourced of the Burned in address.  So just wondering if it is safe to use the floating virtual vs use-bia.
Reza Sharifi
Hi Mohan,
Great! so applying this command affects v6 but was going through the 6.x release notes last night and using ":use-bia" was not recommended ..cannot find that now...but may be due to the above reason...
But which is better to use then?
Thanks and Regards,
Mohan
Hi Mohan,
Just my opinion.
Reza
Hi Reza,
With the traditional one, is it required to hard code mac's on both primary and secondary or is it just dont anything and the defaults will take care of itself..for Virtual MAC i mean.
Hi Mohan,
Reza
Hi Reza,
All done, we have everything configured as above, v2 groups, priorities for active etc, but we had the additional "use-bia" which we will remove to go traditional.
Thanks very much again..
Best Regards,
Mohan
interface Vlan517
  hsrp version 2
  hsrp 517
  hsrp version 2
  priority 110
   ip 192.xx.xx.65
  no shutdown
Reza
Thanks a tonne mate. we are using v2 as well which makes it easy to match those vlan interfaces with the group numbers..thanks a lot again.
Best Regards,
Mohan
Glad to help Mohan.
Good luck and thanks for the ratings
Reza
