HSRP with VRF
I have configured HSRP with VRF's, but don't know how to access from ACTIVE router to BACKUP router by the groups with VRF. I only know to access by the Group without vrf  telnet <ip backup>(from ACTIVE router).
This is the configuration on the ACTIVE router
router1#show running-config interface Ethernet 0/0.20
interface Ethernet0/0.20
encapsulation dot1Q 20
ip address 192.168.0.2 255.255.255.0
no ip redirects
no ip proxy-arp
no cdp enable
standby 20 ip 192.168.0.1
standby 20 priority 105
standby 20 preempt
end
router1#show running-config interface Ethernet 0/0.21
Building configuration...
Current configuration : 343 bytes
interface Ethernet0/0.21
dot1Q 21
ip vrf forwarding VPNIP_Medicina_2020
ip address 192.168.1.2 255.255.255.0
no cdp enable
standby 21 ip 192.168.1.1
standby 21 priority 105
standby 21 preempt
end
router1#show running-config interface Ethernet 0/0.22
Current configuration : 364 bytes
interface GigabitEthernet0/0.22
encapsulation dot1Q 22
ip vrf forwarding VPNIP_ACCESO_INTERNET_2050
ip address 85.80.80.2 255.255.255.0
no cdp enable
standby 22 ip 192.168.2.1
standby 22 priority 105
standby 22 preempt
en
router1#show standby brief
                     P indicates configured to preempt.
Interface   Grp Prio P State    Active          Standby         Virtual IP
e0/0.20    20  105  P Active   local           192.168.0.3     192.168.0.1
e0/0.21    21  105  P Active   local           192.168.1.3     192.168.1.1
e0/0.22    22  105  P Active   local           85.80.80.3       85.80.80.1
How do you to access to standby router by VRF???
thanks,
http://networkingcontrol.wordpress.com/ #CCNP CSCO11962956
acampbell
Alfredo,
I think you mean this
telnet 192.168.1.3 /vrf VPNIP_Medicina_2020
or
ssh -l username -vrf VPNIP_Medicina_2020 192.168.1.3
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Awesome!! This command was!
I didn't remember.
