HSRPs are active!!!!
Ibrahim Jamil
Level 6
Level 6
Hi Expert
Have you seen this issue before , both HSRPs are activebetween R1 AND R2
please help me to solve this issue
Giuseppe Larosa
Hello Ibrahim,
there is no HSRP communication between the two routers they don't see each other HSRP hello messages
they both say standby router unknown, as a result both consider themselves active
check the IP connectivity between the two devices, can they ping each other on that IP subnet? They are likely isolated
Hope to help
Giuseppe
Thanks Giuseppe
glen.grant
  You probably do not have a working L2 path between those interfaces so that the hspf multicast packets can reach each other.  Thus this will put both interfaces into a active state. Those interfaces have to be able to directly talk to each other .
thanks glen
guys , am lucky today , i got two perfect answer within 5 mts
thanks
jamil
