HTTPS Error for Cisco C3850 24P
1eman
Community Member
When I try to access one of our switches via https, we get the "This Page can't be displayed" or "This site can't provide a secure connection" This was working before a power outage occured and when it was restored, it seems to have broken.
http and https are enabled. HTTP and ssh are working fine:
ip http server
ip http access-class 10
ip http authentication local
ip http secure-server
I've tried to delete all keys using "crypto key zeroize rsa" and it did not seem to help. I've also tried to create a new key "crypto key generate rsa modul 1024" and only ssh and http works.
Any advice?
Thanks!
balaji.bandi
SUMMARY STEPS
1.    show ip http server status
2.    configure terminal
3.    ip http secure-server
4.    ip http secure-port port-number
5.    ip http secure-ciphersuite {[3des-ede-cbc-sha] [rc4-128-md5] [rc4-128-sha] [des-cbc-sha]}
6.    ip http secure-client-auth
7.    ip http secure-trustpoint name
8.    ip http path path-name
9.    ip http access-class access-list-number
10.    ip http access-class { ipv4 {access-list-number | access-list-name} | ipv6 {access-list-name} }
11.    ip http max-connections value
12.    ip http timeout-policy idle seconds life seconds requests value
13.    end
here is the config guide for reference :
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/3se/security/configuration_guide/b_sec_3se_3850_cg/b_sec_3se_3850_cg_chapter_01001.html
BB
