Huawei 40G LR Interface with Cisco 9407 with 17.06.04
Ditter
Level 4
Level 4
Hi to all.
i have enabled in the second 40G slot of a 9407 with SUP1 a huawei 40G interface as in the png attached.
The switch does not seem to have understood that. It rus 17.06.04.
Chassis Type: C9407R
Mod Ports Card Type Model Serial No.
1 48 48-Port UPOE 10/100/1000 (RJ-45) C9400-LC-48U
2 48 48-Port UPOE 10/100/1000 (RJ-45) C9400-LC-48U
3 11 Supervisor 1 Module C9400-SUP-1
5 48 48-Port UPOE 10/100/1000 (RJ-45) C9400-LC-48U
6 48 48-Port UPOE 10/100/1000 (RJ-45) C9400-LC-48U
7 48 48-Port UPOE 10/100/1000 (RJ-45) C9400-LC-48U
interface FortyGigabitEthernet3/0/10
enable
end
The switch does not seem to have understood it.
sw1#show int fortyGigabitEthernet 3/0/10
FortyGigabitEthernet3/0/10 is down, line protocol is down (notconnect)
Hardware is Forty Gigabit Ethernet, address is 00be.758d.48b5 (bia 00be.758d.48b5)
MTU 1500 bytes, BW 40000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Auto-duplex, Auto-speed, link type is force-up, media type is unknown
input flow-control is off, output flow-control is unsupported
Last input never, output never, output hang never
Last clearing of "show interface" counters 2w0d
Input queue: 0/375/0/0 (size/max/drops/flushes); Tot
and
sw1#show interfaces fortyGigabitEthernet 3/0/10 transceiver properties
Administrative Speed: auto
Administrative Duplex: auto
Administrative Auto-MDIX: on
Administrative Power Inline: N/A
Operational Speed: auto
Operational Duplex: auto
Operational Auto-MDIX: on
Media Type: unknown
Is anything else i can do in order to be able to use it?
Ditter.
5 Replies 5
Reza Sharifi
Media Type: unknown
You may have an incompatible optic installed on the Cisco switch. Is this a Cisco optic? Was it purchased from a trusted Cisco partner/reseller?
Can you post the part number of the optic?
Thanks for the answer.  It is a huawei optic.
I suppose that the product id is on the photo i attached in my thread.  I googled it and it is the following:
https://support.huawei.com/enterprise/en/doc/EDOC1100095397/18b7d2f3/qsfp-40g-lr4-02310mhs
Ditter
I doubt that a Huawei optic will work on a Cisco switch. I recommend getting one from a Cisco reseller.
Thanks, i have a very large number of these optics as my backbone is 100 Gbps huawei based switches with 100/40/4x25/4x10 ports and i  wondered if i could use these optics on my access 9407Rs also.
I will ask my reseller for cisco compatible ones.
Ditter
arc8882
Why would you use Chinese government parts on your network?  Security not an issue where you work?
