HWIC 9ESW problems
moomoomoo
Hi all,
So I've put a HWIC 9ESW into a 2801 that I've been using for telephony, and am having problems getting to it work :-)
I've read all the similar posts on this subject that I can find, but am still stuck.
This is from the 2801 in question, minus lots of telephony stuff:
interface FastEthernet0/0
 ip address 10.10.10.24 255.255.255.0
 speed 100
 full-duplex
 no mop enabled
interface Service-Engine0/0
 ip unnumbered FastEthernet0/0
 ip virtual-reassembly in
 service-module ip address 10.10.10.14 255.255.255.0
 service-module ip default-gateway 10.10.10.24
interface FastEthernet0/1
 no ip address
 duplex auto
 speed auto
interface FastEthernet0/3/0
 no ip address
interface FastEthernet0/3/1
 no ip address
interface FastEthernet0/3/2
 no ip address
interface FastEthernet0/3/3
 no ip address
interface FastEthernet0/3/4
 no ip address
interface FastEthernet0/3/5
 no ip address
interface FastEthernet0/3/6
 no ip address
interface FastEthernet0/3/7
 no ip address
interface FastEthernet0/3/8
 no ip address
interface Vlan1
 ip address 10.10.11.24 255.255.255.0
ip route 0.0.0.0 0.0.0.0 10.10.10.15
ip route 10.10.10.14 255.255.255.255 Service-Engine0/0
The VLAN on a different subnet was an experiment - ideally everything would be on the same 10.10.10 subnet.
sh vlan-switch
VLAN Name                             Status    Ports
1    default                          active    Fa0/3/0, Fa0/3/1, Fa0/3/2, Fa0/3/3, Fa0/3/4, Fa0/3/5, Fa0/3/6, Fa0/3/7, Fa0/3/8
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
The gateway machine, an 887, has a VLAN 1 on 10.10.10.15:
ip dhcp pool pool1
 import all
 network 10.10.10.0 255.255.255.0
 dns-server 1.1.1.1
 default-router 10.10.10.15
 option 150 ip 10.10.10.24
 lease infinite
interface Ethernet0
no ip address
interface Ethernet0.101
encapsulation dot1Q 101
pppoe enable group global
pppoe-client dial-pool-number 1
no ip address
duplex half
speed 10
interface FastEthernet1
no ip address
duplex half
speed 10
spanning-tree portfast
interface FastEthernet2
no ip address
duplex full
speed 100
interface FastEthernet3
no ip address
duplex full
speed 100
interface Vlan1
ip address 10.10.10.15 255.255.255.0
ip pim dense-mode
ip nat inside
interface Dialer1
mtu 1492
ip address negotiated
ip access-group Inbound-IPv4 in
ip access-group Outbound-IPv4 out
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
ppp mtu adaptive
etc...
I've tried any number of things, but here I am :-)
Any and all suggestions welcome!
Deepak Kumar
What is your issue?
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Haha forgot to mention that :-)
If I plug a mac into the hwic, and do a netstat -nr, it shows every IP address in the subnet, and there is no connectivity.
This happens in most of the configurations that I have tried.
Thanks.
