I am looking for a small switch at least an 8-port...
jvizcarra
I am looking for a small switch at least an 8-port that will fit in a really reduced space... It has to be less than 7 inch deep (front to rear) by no more than 1 3/4 inch thick, and up to 17 inch long or shorter... The reason being is the enclosure... Does anyone out here knows of any Cisco switch that fits this requirement?
6 Replies 6
Kelli Glass
Community Manager
Community Manager
Jacob,
Our Cisco experts have the following recommendation for you:
Our Cisco 110 Unmanaged Switch under our small business family has different models he can choose from. We listed all 8-port switches that meet his size requirements together with their speed, power, and dimensions.
SF110D-08: 5.12 x 1.06 x 5.12 inches (130 x 27 x 130 mm) 8-port 10/100 mbps switch SF110D-08HP: 6.29 x 1.18 x 5.05 inches (160 x 30 x 128.5 mm) 8-port 10/100 mbps switch with PoE (Power over Ethernet) SG110D-08: 5.51 x 1.31 x 5.51 inches (140 x 33.35 x 140 mm) 8-port 10/100/1000 mbps switch SG110D-08HP: 6.29 x 1.18 x 5.05 inches (160 x 30 x 128.5 mm) 8-port 10/100/1000 mbps switch with PoE (Power over Ethernet)
Data Sheet: https://www.cisco.com/c/en/us/products/collateral/switches/110-series-unmanaged-switches/datasheet-c78-734450.html
I hope this helps.
Kelli Glass
Moderator for Cisco Customer Communities
Hello Kelli,
I’m sorry, I forgot to mention the need for a managed switch, I need to trunk over multiple VLANs (at least three)
My mistake, I should have added the requirement.
Thank you
Jacob Vizcarra
Network Services
Office: 805 606-6340, ext. 3151
Mobile: 805 315-8288
Mail: Jacob.vizcarra@ulalaunch.com
Jacob,
Here is the follow-up response for you:
Below is our alternative suggestion if he is looking for a managed switch that can support VLANs:
SG250-10P • Dimensions: 280 x 44 x 170 mm (11.0 x 1.45 x 6.69 in) • 8 10/100/1000 PoE+ ports with 62W power budget • 2 Gigabit copper/SFP combo ports with 60W PoE powered device support • Support for up to 256 active VLANs simultaneously • Port-based and 802.1Q tag-based VLANs • Management VLAN • Ordering SKU: SG250-10P-K9
Data Sheet: https://www.cisco.com/c/en/us/products/collateral/switches/250-series-smart-switches/datasheet-c78-737061.html
The C3560CX-8PT-S is 1.75 x 10.6 x 7.0. You can find the datasheet here.
I hope this is helpful.
Thank you so much…
Thank you
Jacob Vizcarra
Network Services
Great…
I’ll see about getting approval to purchase a few of these… thank you so much.!
Thank you
Jacob Vizcarra
Network Services
