I can not disable QOS on the interface of Catalyst 3750 switch, and I still see output drops on the interface
sam wang
I tried to disable QOS function to a port of switch 3750 by following commands, then tried to clear its counter
(config)#int g3/0/24
                    no mls qos
#clear mls qos interface g3/0/24 statistics
#clear counters g3/0/24
But it doesn't work , I still see some "output drops" on the interface;
I execute "show mls qos int g3/0/24 statistics " command, there are still 11 output drops in queue3 threshold3.(see below)
#sh mls qos int g3/0/24 statistics
GigabitEthernet3/0/24 (All statistics are in packets)
dscp: incoming
  0 -  4 :       12913          0         7642         0            0
  5 -  9 :             0            0            0            0            0
 10 - 14 :           0            0            0            0            0
 15 - 19 :           0            0            0         4527         0
 20 - 24 :           0            0            0            0            0
 25 - 29 :           0            4            0            0            0
 30 - 34 :           0            0            0            0            0
 35 - 39 :           0            0            0            0            0
 40 - 44 :           0            0            0            0            0
 45 - 49 :           0            3            0         1561         0
 50 - 54 :           0            0            0            0            0
 55 - 59 :           0            0            0            0            0
 60 - 64 :           0            0            0            0
dscp: outgoing
  0 -  4 :       40073          0            0            0            0
  5 -  9 :             0            0            0            0            0
 10 - 14 :           0            0            0            0            0
 15 - 19 :           0            0            0            0            0
 20 - 24 :           0            0            0            0            0
 25 - 29 :           0            0            0            0            0
 30 - 34 :           0            0            0            0            0
 35 - 39 :           0            0            0            0            0
 40 - 44 :           0            0            0            0            0
 45 - 49 :           0            0            0          302          0
 50 - 54 :           0            0            0            0            0
 55 - 59 :           0            0            0            0            0
 60 - 64 :           0            0            0            0
cos: incoming
  0 -  4 :       26887        0            0            0            0
  5 -  7 :           0            0            0
  cos: outgoing
  0 -  4 :       44093        0            0            0            0
  5 -  7 :           0          302          503
output queues enqueued:
 queue:    threshold1   threshold2   threshold3
 queue 0:           0           0           0
 queue 1:        4651        0         503
 queue 2:           0           0           0
 queue 3:           0           0       39744
output queues dropped:
 queue 0:           0           0           0
 queue 1:           0           0           0
 queue 2:           0           0           0
 queue 3:           0           0          11   ---> dorps!
Policer: Inprofile:            0 OutofProfile:            0
By command of "show interface g3/0/24" , I also see 11 output drops , and the output data is 57827903 bytes =55.14899 Megabytes during the time
LRC199SW203#sh int g3/0/24
GigabitEthernet3/0/24 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is b0fa.eb62.8f98 (bia b0fa.eb62.8f98)
  Description: 168 xxxx Ave fl 3  AP3602E-160LRC3D
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:06, output 00:00:50, output hang never
  Last clearing of "show interface" counters 00:37:59
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 11  ---> drops!
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 44000 bits/sec, 14 packets/sec
  5 minute output rate 193000 bits/sec, 52 packets/sec
     78282 packets input, 36263371 bytes, 0 no buffer
     Received 158 broadcasts (120 multicasts)
     0 watchdog, 120 multicast, 0 pause input
     121867 packets output, 57827903 bytes, 0 underruns
To make sure I already disabled  QOS on the interface, I type following show commands to verify
"sh mls qos int g3/0/24"
   QoS is disabled. When QoS is enabled, following settings will be applied
   trust state: trust cos
   trust mode: trust cos
   trust enabled flag: ena
   COS override: dis
   default COS: 0
   DSCP Mutation Map: Default DSCP Mutation Map
   Trust device: none
   qos mode: port-based
"sh mls qos int g3/0/24 policers"
sam wang
5 Replies 5
sam wang
the original port configuration is :
interface GigabitEthernet3/0/24
   description 168 xxxxx fl 3  AP3602E-160LRC3D
   switchport access vlan 610
   switchport mode access
   srr-queue bandwidth share 1 30 35 5
   priority-queue out
   mls qos trust cos
   auto qos trust
   spanning-tree bpduguard enable
   ip dhcp snooping trust
sam wang
If you dont want qos action on this interface, can you try to remove below commands from the interface.
   srr-queue bandwidth share 1 30 35 5 <<<<<<<<<<<
   priority-queue out   <<<<<<<<<<<<<<
   mls qos trust cos   <<<<<<<<<<<<<
   auto qos trust         <<<<<<<<<<<<<<
Akash
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
My experience on 3750 has been generally only a reload will clear the detailed MLS QoS stats.
However, I thought could could clear the interface stats, although, if not, might be a bug in your IOS version (you didn't note actual 3750 model or specific IOS version being used).
Lastly, the interface stats don't clear at all?  Reason I ask, disabling QoS doesn't preclude you still getting drops.
I did disable QOS funcation and removed all QOS related commands in the interface, then reloaded the switch ,  but still see outputs drops.
sam wang
Disclaimer
Posting
Disabling QoS doesn't not eliminate the possibility of output drops, and they will still be counted.  However, did all the counters reset with the reload, and do the drops now all only accumulate in one counter?
