i can't ping sub-interface from C8500L-8S4X to sub-interface NCS540 ,
Dhikra Marghli
Level 5
Level 5
Hello
i have a :C8500L-8S4X  connect to NCS540-CISCO
so my problem i can't ping sub-interface from this router to sub-interface NCS540 ,
so please how i can resolve this problem that i can ping to sub-interfce point-point NCS540 CISCO
so you wil have configuration C8500L
license udi pid C8500L-8S4X sn FLX261803Y0
memory free low-watermark processor 67727
diagnostic bootup level minimal
redundancy
mode none
cdp run
--More--  !
interface GigabitEthernet0/0/0
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/1
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/2
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/3
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/4
no ip address
--More--   shutdown
negotiation auto
interface GigabitEthernet0/0/5
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/6
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/7
no ip address
shutdown
negotiation auto
interface TenGigabitEthernet0/1/0
no ip address
interface TenGigabitEthernet0/1/0.3022
encapsulation dot1Q 3022
--More--   ip address 172.25.40.162 255.255.255.252
interface TenGigabitEthernet0/1/1
no ip address
shutdown
interface TenGigabitEthernet0/1/2
no ip address
shutdown
interface TenGigabitEthernet0/1/3
no ip address
shutdown
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
ip http server
ip http authentication local
ip http secure-server
--More--  ip forward-protocol nd
ip tftp source-interface GigabitEthernet0
control-plane
line con 0
stopbits 1
line aux 0
line vty 0 4
login
transport input ssh
NCS540===>ip address 172.25.40.161 255.255.255.252
I wait a reply from expert switching
22 Replies 22
Torbjørn
That configuration looks fine and should allow pinging the NCS540 address. What does the configuration for the interface(s) on the NCS540 look like? Is the interface up?
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
Hello
This configuration in NCS 540 point-to-ponit to C8500L-8S4X
interface TenGigE0/0/0/22.3022 l2transport
description INBMI
encapsulation dot1q 3022
rewrite ingress tag pop 1 symmetric
and this configuration is UP UP
so how i can edit configuration that allow ping  from 8500 to NCS540
I wait a reply
M02@rt37
Hello @Dhikra Marghli,
Please provide us the NCS and c8500 output of #show ip interface brief command.
Best regards
Hello
description INBMI
I wait a reply
@Dhikra Marghli
It is a P2P connection? Why l2transport? No VPLS needed.
description INBMI
Best regards
Thanks for your reply
Telecom operator who works on this nCS54 equipment cannot change configuration on NCS 540  and he tells me how to change configuration in interafce C8500L-8S4X  so that allows ping interface from NCS54 to  C8500L-8S4X ??
so please how i can change configuration in  C8500L-8S4X ???
Hello
I wait your help please !!
Router#show ip arp
Protocol Address Age (min) Hardware Addr Type Interface
Internet 172.25.40.162 - 4488.162d.a688 ARPA TenGigabitEthernet0/1/0.3022
No @MAc  from NCS540 cisco
Why are you using an l2transport configuration on the NCS540?  Is this part of an L2VPN where you are transporting Ethernet frames from one attachment circuit to another?  If not, and you only want an L3 interface, get rid of the "l2transport" keyword and replace the "rewrite" config with "ipv4 address 172.25.40.161/30"
Disclaimers: I am long in CSCO. Bad answers are my own fault as they are not AI generated.
Operator Telecom send me from NCS540 :
and he say  me that this interface in NCS540 is conneted directly to C8500L-8S4X ( p2P)  . Yes , interface in NCS540 is L2VPN
so i can't unterstand how i can edit configuration C8500L-8S4X !!!! that allow to interface in NCS540 !!
RP/0/RP0/CPU0:NCS540-Kasbah-DCN#show l2vpn forwarding bridge-domain BUSINESS-C$
Tue Oct 31 12:13:12.615 CET
To Resynchronize MAC table from the Network Processors, use the command...
    l2vpn resynchronize forwarding mac-address-table location <r/s/i>
Mac Address    Type    Learned from/Filtered on    LC learned Resync Age/Last Change Mapped to
b08b.d021.c40e dynamic (10.1.211.19, 513543022)    N/A        31 Oct 12:13:13        N/A
The address 172.25.40.161 must be attached to an L3 construct (interface), while NCS540 int TenGigE0/0/0/22.3022 is an L2 construct. Has the operator of the NCS540 said where this IP address is attached? To a BVI perhaps?
The L2VPN config from the NCS540 is incomplete, as it is only showing the TenGigE0/0/0/22.3022 attachment circuit and not how/where the ethernet frames are being transported by the 540. Ask the operator for the complete L2VPN config for your service.
Operator say me that configuration is from NCS540 cisco is interface L2
and this NCS540 is connted to router Busniess-PE
this B-PE is conneted to C8500L-8S4X
so configuration in B-PE router : ASR9K has interface L3
so  Operator Telecom say me to edit configuration in 8500L !
so please how i can resolve this problem that allow ping from B-PE to 8500L
Hello
i explain you topologie but Operator insist  change configuration in 8500L !!!
hi
what do you thaink please !! i explain you !! thanks
