i have 4510R switch with dual V-10GE sup
nilesh.varade
I have connected this particular 4510R switch to other access swtiches in ring topology.
To complete this ring, i have connected one 10G of SUP-1 in slot 1 i.e 1/1 and another link on 2/1 on SUP-2 to complet Ring topology.
But whenever i check show interface status, it shows 10G 2/1 port is inactive. by defualt this port should be in Active state.
Please guide me what will b the problem. or wat shud i do in this scenario.
Output:
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-IPBASEK9-M), Version 12.2(31)SGA10, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Fri 12-Jun-09 15:33 by karnagar
Image text-base: 0x10000000, data-base: 0x115D7330
ROM: 12.2(31r)SGA
Pod Revision 14, Force Revision 34, Tie Revision 32
CORE_4510R uptime is 1 year, 21 weeks, 18 hours, 53 minutes
Uptime for this control processor is 23 weeks, 6 days, 7 hours, 35 minutes
System returned to ROM by redundancy reset
System restarted at 04:22:48 GMT Sat Feb 26 2011
System image file is "bootflash:cat4500-ipbasek9-mz.122-31.SGA10.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C4510R (MPC8540) processor (revision 11) with 524288K bytes of memory.
Processor board ID FOX092905M9
MPC8540 CPU at 800Mhz, Supervisor V-10GE
Last reset from Redundancy Reset
3 Virtual Ethernet interfaces
350 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
------------------ show module ------------------
Chassis Type : WS-C4510R
Power consumed by backplane : 40 Watts
Mod Ports Card Type                              Model              Serial No.
1     6  Sup V-10GE 10GE (X2), 1000BaseX (SFP)  WS-X4516-10GE      JAE1015ZVQG
2     6  Sup V-10GE 10GE (X2), 1000BaseX (SFP)  WS-X4516-10GE      JAE1036AN0B
3     6  1000BaseX (GBIC)                       WS-X4306-GB        JAE0947QJLG
4    48  10/100/1000BaseT (RJ45)                WS-X4548-GB-RJ45   JAE0931HC12
5    48  10/100/1000BaseT (RJ45)                WS-X4548-GB-RJ45   JAE0930GWKG
6    48  10/100/1000BaseT (RJ45)                WS-X4548-GB-RJ45   JAE0916ABXA
7    48  10/100/1000BaseT (RJ45)                WS-X4548-GB-RJ45   JAE1052JDHN
8    48  10/100/1000BaseT (RJ45)                WS-X4548-GB-RJ45   JAE1038BY7G
9    48  10/100/1000BaseT (RJ45)                WS-X4548-GB-RJ45   JAE15080CF9
10    48  10/100/1000BaseT (RJ45)                WS-X4548-GB-RJ45   JAE1516099D
M MAC addresses                    Hw  Fw           Sw               Status
1 0015.c60d.4740 to 0015.c60d.4745 3.3 12.2(31r)SGA 12.2(31)SGA10    Ok
2 0015.c60d.4746 to 0015.c60d.474b 3.3 12.2(31r)SGA 12.2(31)SGA10    Ok
3 0015.630c.4088 to 0015.630c.408d 4.0                               Ok
4 0015.2bf0.1480 to 0015.2bf0.14af 2.1                               Ok
5 0015.2bef.fc20 to 0015.2bef.fc4f 2.1                               Ok
6 0013.c300.0390 to 0013.c300.03bf 2.2                               Ok
7 001a.6c18.2ff0 to 001a.6c18.301f 2.3                               Ok
8 0019.2f9a.3180 to 0019.2f9a.31af 2.3                               Ok
9 503d.e5a3.7710 to 503d.e5a3.773f 2.5                               Ok
10 c89c.1da9.e7c0 to c89c.1da9.e7ef 2.6                               Ok
Mod  Redundancy role     Operating mode      Redundancy status
1   Active Supervisor   SSO                 Active
2   Standby Supervisor  SSO                 Standby hot
Reza Sharifi
Are you connecting both ports from the 4500 to the same access switch using Etherchannel or multiple switches?
What is the topology?
there are four switches in Ring Topology....starts with 4510R and ends with 4520R...
From where it starts tat is connected on SUP-1 V-10GE port number 1/1 and Ring completes with SUP-2 V-10GE on port 2/1.
In this case 2/1 should be active as per my knowledge but its showing inactvie
Nilesh,
Prior to Cisco Release 12.2(25)SG, the Cisco Catalyst 4500
Supervisor Engine V-10GE allowed you to enable either the dual
wire-speed 10-Gigabit Ethernet ports, or four alternatively wired
Gigabit Ethernet SFP uplink ports. With Cisco Release 12.2(25)SG, you
can simultaneously deploy the dual 10 Gigabit Ethernet ports and the
four Gigabit Ethernet SFP ports. This capability is supported on the
Catalyst 4503, Catalyst 4506, and Catalyst 4507R chassis.
When deploying a Catalyst 4510R chassis, one of three configurations is
supported:
* Enable the dual 10 -Gigabit Ethernet ports (X2 optics) only.
*Enable the four Gigabit Ethernet ports (SFP optics) only.
*Enable both the dual 10 Gigabit Ethernet and the four Gigabit Ethernet
ports, with the understanding that the tenth slot (Flex-Slot) will only
support a 2-port gigabit interface converter (GBIC) line card
(WS-X4302-GB) when in this mode.
Do you have the gig ports enabled as well?
The command hw-module uplink select is required to activate the links.
Below is the cisco link which explains the above statements
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/31sga/con
figuration/guide/sw_int.html#wp1066964
Amit
Thanks Amit,
My current IOS is Version 12.2(31)SGA10. Does this IOS supports as you said earlier...
If i do not use "hw-module uplink select", i think it should not show inactive because by default two 10GE in dual sup shows active.
or i will have to use above command in current IOS.
