I have a Problem with my Packet tracer.
Hello everyone!
I have a problem with my packet tracer interface which isn't working fine these days. I don't know why?
But I think I have made some changes and those changes caused me this issue.
The issues are that when I open packet tracer every time it asks me about my login credentials which normal but it asks every time like after 5 seconds if I close and reopen the application it asks me.
next is that I change the font size every time but when I left and come back like after 5 seconds it again changes to default.
also, the lights of the port are not working fine but I'm quite okay with it.
anyone knows how to figure it out.
Thank you.
omz
Download latest version and install again
Deepak Kumar
In the latest version of PT, you have to login every time on opening the software. For other issues better to reinstall.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Martin L
There were some problems with PT; lots of issues with PT for MAC version.
I would try the latest version; make sure you use correct X-bit version for your OS type.
Still recommend Windows OS despite the fact that issues seemed to be solved for MAC users (may still depend on MAC OS version)
Regards, ML
**Please Rate All Helpful Responses **
