Cisco 2960 + Hardening
RS19
Level 4
Level 4
We have deployed Cisco 2960 switch in environment & as general practice we used to do scanning of the network devices to check for any unwanted port open.
When we did for Cisco 2960 switch, the switch was not listening to any of the TCP ports.
Would like to know by default what is the security or hardening applied on Cisco 2960 switches ?
Any reference document if any please share.
6 Replies 6
Leo Laohoo
Thanks. But it did not mention about what is the default hardening enabled in Cisco switches ?
Why there is no listening of TCP ports ?
Switch come with Default configuraiton, based on Location of place where the switch installed required more security to protect device from attacks.
you can view what ports open by issuing the command :
show control-plane host open-ports
show ip sockets
BB
Thanks.
I checked the below command , but it is not accepting
The below command worked.
show ip sockets
But it shows only UDP ports as per the below link.
https://packetlife.net/blog/2008/dec/3/listing-open-sockets-ios/
Joseph W. Doherty
I don't recall running across a document that lists default security settings.
I have noticed, over the years, newer platforms/IOSs have more of the "recommended" security settings (like those noted in Leo's suggested document) configured by default. I've also noticed such later systems take advantage of "features" perhaps not described as recommendations in those security documents, like placing the management port into its own VRF.
On lower end switches, I recall (many years ago, Cisco Configuration Assistant or Cisco Network Assistant [last ver. 6.3.4 -12/18]) that some of these configuration utilities sometimes having a "security check" that will list what security settings are configured, or not, and offer to change non-configured to features to "on".
johnlloyd_13
Level 9
Level 9
hi,
there's no 'default' device hardening per se.
you need to discuss this with your IT management and define what ports and protocols that needs to be secured/hardened and what would be its impact.
i used the CIS doc as a start but there are other vendor neutral docs out there:
https://www.cisecurity.org/wp-content/uploads/2017/04/CIS_Cisco_IOS_Benchmark_v2.2.pdf
