i have a question :)
fb_webuser
Level 6
Level 6
does Cisco 2600 series switch support 802.1x and DHCP snooping?
Posted by WebUser Neon Rain
6 Replies 6
fb_webuser
Level 6
Level 6
Depends on image. Generally support as I know
Posted by WebUser Aleksandr Yanovskiy
Leo Laohoo
2600 switch???
fb_webuser
Level 6
Level 6
http://www.tftp-server.com/ You can use this for MS platform. One time I have no responsibility lo load image by TFTP, I loaded image 30 minutes, by tftp it takes near 5 minutes.
When you choose speed of Xterm, for exmaole 9600, its 9600bits per second. So you can calculate time you need to load image
fb_webuser
Level 6
Level 6
leolaohoo, you are right 2600 is router
fb_webuser
Level 6
Level 6
actually i meant legacy switches below catalyst 2950 series, i read in some pages which suggested we have to add new interfaces to support 802.1x features in legacy switches/routers so... well thanks for the info n the link.
Hi Neon
Catalyst 2960 supports mentioned features.
You can run "Cisco Feature Navigator" to check which image you need for it.
HTH,
Alex
