i have problem in cisco 7600 , all interfaces have the same MAC !!!
Dr.X
Level 2
Level 2
hi ,
i have a problem in network ,
i tried to connected two interfaces of my router cisco 7600 with another switch . cisco 2960
but i noted a fl;apping error message  on the other switch (2960g)
*Mar  2 02:48:40.788: %SW_MATM-4-MACFLAP_NOTIF: Host 503d.e5af.9c40 in vlan 1 is flapping between port Gi0/5 and port Gi0/22
as you see above , there is duplication in the mac address.
i tired my interfaces show in my router cisco 7600
Gateway7600#sh interfaces gigabitEthernet 1/1
GigabitEthernet1/1 is up, line protocol is up (connected)
  Hardware is C6k 1000Mb 802.3, address is 503d.e5af.9c40 (bia 503d.e5af.9c40)
Gateway7600#sh interfaces gigabitEthernet 1/2
GigabitEthernet1/2 is up, line protocol is up (connected)
Gateway7600#sh interfaces gigabitEthernet 1/3
GigabitEthernet1/3 is down, line protocol is down (notconnect)
as you see above , the three interfaces has the same MAC address !!!!!!!
here is sh version of my model :
Gateway7600#sh version
Cisco IOS Software, c7600s3223_rp Software (c7600s3223_rp-ADVENTERPRISEK9-M), Version 15.2(1)S, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Sun 27-Nov-11 15:27 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX3, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, c7600s3223_rp Software (c7600s3223_rp-ADVENTERPRISEK9-M), Version 15.2(1)S, RELEASE SOFTWARE (fc1)
Gateway7600 uptime is 1 day, 2 hours, 35 minutes
Uptime for this control processor is 1 day, 2 hours, 35 minutes
System returned to ROM by power-on (SP by power-on)
System image file is "sup-bootdisk:c7600s3223-adventerprisek9-mz.152-1.S.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco CISCO7604 (R7000) processor (revision 2.0) with 458752K/65536K bytes of memory.
Processor board ID FOX1509G2DK
R7000 CPU at 300MHz, Implementation 39, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
1 Virtual Ethernet interface
9 Gigabit Ethernet interfaces
1915K bytes of non-volatile configuration memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
plz help
regards
Hiho, Hey Pete =)
This is default behavous for the 7600 (I know it's kinda crazy!), there is a tech doc for it;
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a00801c9b4e.shtml
You can change the MAC address using mac-address interface command.
Can I ask, are the ports on the 7600 configured as routed ports? I ask because if they are they will all have the same MAC & the 2960 you are connected to only speaks layer 2.
If you change the interfaces back to switch ports;
Interface Gi1/1
switchport
They should then be assigned an individual MAC on a per port basis. However being unfamiliar with your topology this may not be a solotuion for your design goal, in which case I would manually change the MAC so that the layer 2 fabric on the 2960 stays happy =)
Sam.
9 Replies 9
Peter Paluch
I am going to say right away that I do not work with 7600 series routers so I hope someone else who is more experienced will join the thread. Still, let us at least try to pull out some diagnostic information.
  • Is the router currently running an empty configuration, or is there already some configuration present? Can you perhaps post the current running-config?
  • Can you post the output of the show inventory command? We will need to know the line card type you are using.
Best regards,
Peter
Hiho, Hey Pete =)
Interface Gi1/1
switchport
Sam.
Edison Ortiz
Did you configure port-channel in the 7600 switch?
When connecting multiple inter-switch links, one interface would be in blocking mode preventing the error you are seeing.
Only when configuring port-channel on a peer switch, you would see this kind of behavior.
The 7600 is built on the same 6500 architecture where the switch would use the same MAC under all interfaces.
Hello Edison,
It is so nice to read from you again! Oh, I owe you an e-mail response - sorry for that, I keep it in mind, though!
Are you saying here that when you configure a port-channel on 7600, the MAC addresses on physical switchports will be reconfigured? I haven't observed the same behavior on 29xx/35xx series switches. The virtual Port-channel interface will inherit one MAC address from the bundled physical ports but I have never seen the MAC addresses on the individual physical ports to be changed to a single MAC.
Best regards,
Peter
Hi Peter, hope you had a wonderful Christmas!
No, I'm referring to the fact if you configure a port-channel, both ports will be in FWD mode and the peer switch will see the same MAC from the neighbor device. Loop prevention will try to prevent the packets coming from both interfaces hence the message is displayed.
If port-channel isn't configured, one port will be in FWD mode while the second port will be in BLK mode.
Edison, I dont think that port-channel is to blame here, If it were in a port channel the error would not be;
I would expect it to look more like;
Mar  2 02:48:40.788: %SW_MATM-4-MACFLAP_NOTIF: Host 503d.e5af.9c40 in vlan 1 is flapping between port Po1 and ports Po1
Or am I of the mark here? But as metioned before this is default behaviour for this model.
Sam.
He is seeing the message on the 2900 switch which is not configured as port-channel.
hi all , im really appreciating your help ,
as sam said , we can change  the mac manually  by the command :
im really surprised to know that the mac can be changed by cli command .
plz have a look here
GigabitEthernet1/3 is administratively down, line protocol is down (disabled)
  Hardware is C6k 1000Mb 802.3, address is 503d.e5af.9c50 (bia 503d.e5af.9c40)
this is after i changed the mac under the interface command
as u see , look at the last two  digits of the mac address now , but it seems bia is the same  !
=>note  that im using the default seettings as a router not as a switch .
=>no portchannel is used .
as soon as u talked about 7600 model , i want to ask a question.
1-is there a supervisor  module  can be intergrated with cisco 7600  that can support 10 giga interface ????
2-  currently i have only 1 power supply is connetced with electricity , and there is another power supply not connected to electricity ,now if i want to connect both the two power supplies for redundancy , do i need to do commands on cli ??
and how to verify the stautus of power supplies ???
here is show inventory as your request :
Gateway7600#sh inventory
NAME: "CISCO7604", DESCR: "Cisco Systems Cisco 7600 4-slot Chassis System"
PID: CISCO7604         , VID: V01, SN: FOX1509G2DK
NAME: "CLK-7600 1", DESCR: "OSR-7600 Clock FRU 1"
PID: CLK-7600          , VID:    , SN: NWG150300S7
NAME: "CLK-7600 2", DESCR: "OSR-7600 Clock FRU 2"
NAME: "module 1", DESCR: "WS-SUP32-GE-3B 9 ports Supervisor Engine 32 8GE Rev. 4.4"
PID: WS-SUP32-GE-3B    , VID: V04, SN: SAD104204GX
NAME: "msfc sub-module of 1", DESCR: "WS-F6K-MSFC2A Cat6k MSFC 2A daughterboard Rev. 3.1"
PID: WS-F6K-MSFC2A     , VID:    , SN: SAD104004UC
NAME: "switching engine sub-module of 1", DESCR: "WS-F6K-PFC3B Policy Feature Card 3 Rev. 2.3"
PID: WS-F6K-PFC3B      , VID: V01, SN: SAD104201HK
NAME: "Transceiver Gi1/1", DESCR: "Transceiver 1000BaseT Gi1/1"
PID: N/A               , VID: 10.0, SN: MTB0010352
NAME: "Transceiver Gi1/2", DESCR: "Transceiver 1000BaseT Gi1/2"
PID: N/A               , VID: 10.0, SN: MTB0010350
NAME: "Transceiver Gi1/3", DESCR: "Transceiver 1000BaseT Gi1/3"
PID: N/A               , VID: 10.0, SN: MTB0010347
NAME: "FAN-MOD-4HS 1", DESCR: "High Speed Fan Module for CISCO7604 1"
PID: FAN-MOD-4HS       , VID: V01, SN: DCH15050161
NAME: "PS 1 PWR-2700-AC/4", DESCR: "2700W AC power supply for CISCO7604 1"
PID: PWR-2700-AC/4     , VID: V02, SN: APS1503002C
NAME: "PS 2 PWR-2700-AC/4", DESCR: "2700W AC power supply for CISCO7604 2"
PID: PWR-2700-AC/4     , VID: V02, SN: APS1503002J
wish it help
regards
Ahmad
Please refer to the following link for Supervisor Module with 10Gbps support
http://www.cisco.com/en/US/prod/collateral/routers/ps368/product_data_sheet0900aecd8072579f.html
Please Note: You will need to replace your current Supervisor with this one.
You can't have dissimilar Supervisors in a chassis.
The power default setting will be 'redundant' by default and the verification command is 'show power'
More info @
http://www.cisco.com/en/US/docs/routers/7600/ios/15S/configuration/guide/pwr_envr.html
