Showing results forĀ
Search instead forĀ
Did you mean:Ā
i have two error console loggs i want explanationfor them
Dr.X
Level 2
Level 2
hi , i have error console msg on my router 7600 which is MLS
Jan  2 15:19:33.624: %ADJ-3-RESOLVE_REQ: Adj resolve request: Failed to resolve x.x.65.250 GigabitEthernet1/2
what does this mean ???????/
i have another error message which appeared yesterday when i did some modifications in my topology and my cpu was 100 %
Dec 31 17:55:15.008: %IPRT-3-RIB_LOOP: Resolution loop formed by routes in RIB
plz adviceabout the two error messages above
regards
8 Replies 8
Edison Ortiz
Regarding the first message, what IOS version are you running?
Regarding the second message, it seems you have recursive routing - can you provide your running configuration?
hi , im using MLS 7600
Gateway7600#sh version
Cisco IOS Software, c7600s3223_rp Software (c7600s3223_rp-ADVENTERPRISEK9-M), Version 15.2(1)S, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Sun 27-Nov-11 15:27 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX3, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, c7600s3223_rp Software (c7600s3223_rp-ADVENTERPRISEK9-M), Version 15.2(1)S, RELEASE SOFTWARE (fc1)
Gateway7600 uptime is 1 week, 1 day, 11 hours, 22 minutes
Uptime for this control processor is 1 week, 1 day, 11 hours, 22 minutes
System returned to ROM by power-on (SP by power-on)
System restarted at 10:22:25 UTC Tue Dec 25 2012
System image file is "sup-bootdisk:c7600s3223-adventerprisek9-mz.152-1.S.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco CISCO7604 (R7000) processor (revision 2.0) with 458752K/65536K bytes of memory.
Processor board ID FOX1509G2DK
R7000 CPU at 300MHz, Implementation 39, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
1 Virtual Ethernet interface
9 Gigabit Ethernet interfaces
1915K bytes of non-volatile configuration memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
about the 2nd message , it occured when i performed alot of changes in my topology , but now its not appearing , i mean it appeared when the topoloy has changed .
but can it give an indication for a specific thing ??? note that my cpu reached 100 % of 7600 MLS , and i couldnt continue , so i returned my topology as before .
can i know wts wrong ???
regards
That error has been seen on 15.x code train - no workaround at this moment:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCts29063
Please note, while the bug details list ASR1K and Port-Channel as part of the issue, it has also been seen on 7600 and regular interfaces.
Try upgrading to 15.2(4)S2
is it sure an ios bug ???
also
wt about the 2nd error log ?
regards
All of your symptoms match the bug.
The 2nd error could be due to recursive routing in place. Since you were making a lot of topology changes, a route pointing to a recursive route may have not been present. Due to a timing issue, the error came up. I will disregard if you don't see it again.
so u think that upgrading the ios may solve the issue ??
what ios do u suggest to upgrade to the 7600 MLS ?
regards
As I stated, try upgrading to 15.2(4)S2
thanks soo much , i wish the problem be solved the next time when the ios has been updated
regards
