I need help with a Terminal access server
shinji7800
I try to configure a C2901 with two Hwic-16A.
when I try to send a configuration on a client, the server send to quickly commands and the client don't manage the flow.
there is a lot of errors  because commands line are merged ! (there is a lot of commands errors)
I don't understand how can I wait that the first command line is entirely send before send the second one ! like a delay between each line (from the clipboard)
I use putty with a ssh connection
best regards
shinji7800
There is something wrong with my post ?
do I change something ?
thanks
best regards
