I need some help creating named ACLs for NAT
Bimsara
Hi Everyone,
I have to create a named ACL to allow VLAN105 to access to NAT address pool,
Using NAT overload on the pool,
the NAT Pool public Address Range is 183.1.0.0/26
the VLAN 105 network is 192.168.2.0/25
i have attached the packet tracer file as well using zip, Any help would be much appreciated, thank you.
 So far i have configured this on the Blue Router, but i don't see any translations when i type 'show ip nat statistics' command.
hostname Blue
ip dhcp excluded-address 192.168.2.126
ip dhcp pool VLAN105
network 192.168.2.0 255.255.255.128
default-router 192.168.2.126
no ip cef
no ipv6 cef
username Blue password 0 ccna34
spanning-tree mode pvst
interface Loopback0
ip address 192.168.2.145 255.255.255.248
interface GigabitEthernet0/0/0
no ip address
duplex auto
speed auto
shutdown
interface GigabitEthernet0/0/1
no ip address
duplex auto
speed auto
shutdown
interface Serial0/1/0
ip address 192.168.2.153 255.255.255.252
encapsulation frame-relay
frame-relay map ip 192.168.2.153 115
ip nat inside
clock rate 2000000
interface Serial0/1/0.115 point-to-point
no ip address
clock rate 2000000
shutdown
interface Serial0/1/1
ip address 70.14.1.13 255.255.255.252
encapsulation ppp
ip nat outside
interface Vlan1
no ip address
shutdown
router eigrp 10
passive-interface Loopback0
network 192.168.2.152 0.0.0.3
ip nat pool VLAN105 183.1.0.1 183.1.0.62 netmask 255.255.255.192
ip nat inside source list VLAN105 pool VLAN105 overload
ip classless
ip route 0.0.0.0 0.0.0.0 70.14.1.14
ip flow-export version 9
ip access-list extended VLAN105
permit ip 192.168.2.0 0.0.0.127 183.1.0.0 0.0.0.63
permit ip any any
banner motd ^C^C
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
ipv6 access-class VLAN105 in
password cisco
login
end
Blue(config)#do show ip nat trans
Blue(config)#do show ip nat stat
Total translations: 0 (0 static, 0 dynamic, 0 extended)
Outside Interfaces: Serial0/1/1
Inside Interfaces: Serial0/1/0
Hits: 0 Misses: 1425
Expired translations: 77
Dynamic mappings:
-- Inside Source
access-list VLAN105 pool VLAN105 refCount 0
pool VLAN105: netmask 255.255.255.192
start 183.1.0.1 end 183.1.0.62
type generic, total addresses 62 , allocated 0 (0%), misses 0
Leo Laohoo
To all concerned,
It is very clear this thread is school work.
Help the students learn: Post the links to documents and configuration guides.
Please refrain from handing out answers.
