i need to change stack cable from member switch to member switch
dc-csa-blr
Hi All,
i have an 4 switches in stack wise connection. there is a problem in one of the stack cable i need to change the stack cable between 1 & 4.
Do i need to switch off the switch in order to add a new cable to existing member switch..
6 Replies 6
Yogesh Ramdoss
Generally, you don't have to power-off any switch, while replacing stack cable.
I am not sure about the complete stack cable connections.
Please send "sh switch neighbor" with "sh ver | inc IOS"
- Yogesh
Hi Yogesh,
------------------ show switch detail ------------------
Switch/Stack Mac Address : 0013.1945.1080
                                           H/W   Current
Switch#  Role   Mac Address     Priority Version  State
1       Member 0013.1945.5600     1      0       Ready
*2       Master 0013.1945.1080       1      0       Ready
3       Member 0013.1945.1100     1      0       Ready
4       Member 0013.1945.3b80     1      0       Ready
         Stack Port Status             Neighbors
Switch#  Port 1     Port 2           Port 1   Port 2
  1        Ok        Down               2      None
  2        Ok         Ok                3        1
  3        Ok         Ok                4        2
  4       Down        Ok              None     None
i was trying to replace 1  & 4 .
I guess you are trying to replace the stack cable connected between Sw1-SP2<<==>>Sw4-SP1. If so, it shouldn't be a problem.
Did you notice the stack cable connection between Sw3-SP1 <<===> Sw4-SP2 ?
From the command results, I see Sw4 has no stack neighbors.
- Yogesh
Thx Yogesh..
Can i get any document that states we can remove the stack cable while switch was running...
Thaks again
I am not aware of any document that provides the details you requested.
Managing Switch Stacks - doc on CCO:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_55_se/configuration/guide/swstack.html
- Yogesh
glen.grant
Shouldn't be a problem just pulling one cable , the ring will wrap and run at half bandwidth I believe  until the cable is replaced.
