10-14-2015 01:29 AM - edited 03-08-2019 02:12 AM
Dear All,
I'm facing problem with latency to point to point IP configured on cisco L3 switch. switch details as follows.
Model: WS-C3750X-24
Flash:c3750e-universalk9-mz.152-2.E.bin
UPCOUNTRY-L3#sh int g 1/0/10
GigabitEthernet1/0/10 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 4c00.829b.43ff (bia 4c00.829b.43ff)
Description: ICMP-TEST
Internet address is 192.168.1.1/30
MTU 9000 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 00:00:01
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 678000 bits/sec, 80 packets/sec
5 minute output rate 822000 bits/sec, 104 packets/sec
17 packets input, 1231 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 watchdog, 0 multicast, 0 pause input
17 packets output, 9846 bytes, 0 underruns
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
interface GigabitEthernet1/0/10
description ICMP-TEST
no switchport
ip address 192.168.1.1 255.255.255.252
end
And checked with changing patch cable from switch to pc and checked changing the pc also result were same. Kindly suggest what to do.
10-14-2015 02:39 AM
Do you mean connect a PC to 3750X g 1/0/10, PC ip address 192.168.1.2 255.255.255.252, then PC ping 192.168.1.1 with high delay?
If yes, then it should be a normal behavior.
10-14-2015 03:42 AM
Yes it was same, but it should not be like that. Kindly suggest some command to rectify it.
10-14-2015 03:14 AM
Whats the status of pinging other devices on the same switch ?? regardless network prefix is /30
10-14-2015 03:40 AM
Yes we are facing problem in the all the ports regardless network prefix.
10-14-2015 07:28 AM
10-14-2015 08:23 AM
Hi, I will try it today and let you know the status
10-15-2015 01:58 PM
