ICMP response
followurself
Level 5
Level 5
we had a server with ip 10.1.100.17, connected to LAN.but now tht server is shutdown. but still when i ping the IP this is wht i get
Pinging 10.1.100.17 with 32 bytes of data:
Reply from 10.1.100.17: bytes=32 time<1ms TTL=255
Request timed out.
atleast one packet loss. But we know the server isnt connected. The layer 3 switch 6509 with
6509> (enable) sh module 15
Mod Slot Ports Module-Type Model Sub Status
15 1 1 Multilayer Switch Feature WS-F6K-MSFC2 no ok
Mod Module-Name Serial-Num
15 SAD05060Y0K
when is look at my arp table on my pc it shows 00-d0-04-f4-ab-fc
weh checked on the switch with
_6509> (enable) sh cam msfc 15 100
Physical MAC-Address for Module 15 interfaces: 00-d0-04-f4-ab-fc
VLAN Destination MAC Destination Ports or VCs
100 00-d0-04-f4-ab-fc 15/1
Total Matching CAM Entries Displayed = 1
Its the mac address of module 15 which the engine..whats wrng? whts going on?
14 Replies 14
Any possibility that the MSFC is configured with this specific address?
Hope this helps,
Anand Narayana
Level 11
Level 11
what i would suggest you is, just login to the layer 3 module, type "show ip arp 10.1.100.17" juz find the mac-address of this ip address & then come out from the layer 3 module from the cisco 6509 switch interface type "show cam ab:cd:ef:gh:ij:kl" it should show where exactly the mac-address is residing, with that you can come to know whether the MSFC is using the IP address or it is pointing to any other pc.
eg.
Cat6509>(enable)session 15
MSFC#show ip arp 10.1.100.17
Protocol Address Age (min) Hardware Addr Type Interface
Internet 10.1.100.17 0 abc.efgh.ijkl ARPA Vlan2
Cat6509>(enable)show cam ab:cd:ef:gh:ij:kl
VLAN Dest MAC/Route Des [CoS] Destination Ports or VCs / [Protocol Type]
2 ab-cd-ef-gh-ij-kl 1/1 [ALL]
hope this helps.
rate this post if cleared.
Thanks , its the MSFC using the ip .below is the output from show mac output..and its the module on which msfc is connected. But why wd MSFC suddenly use this IP. how do i make it not to use it?
2 00-d0-04-f4-ab-fc R#
100 00-d0-04-f4-ab-fc R#
101 00-d0-04-f4-ab-fc R#
102 00-d0-04-f4-ab-fc R#
103 00-d0-04-f4-ab-fc R#
104 00-d0-04-f4-ab-fc R#
105 00-d0-04-f4-ab-fc R#
106 00-d0-04-f4-ab-fc R#
107 00-d0-04-f4-ab-fc R#
108 00-d0-04-f4-ab-fc R#
109 00-d0-04-f4-ab-fc R#
110 00-d0-04-f4-ab-fc R#
How do i make MSFC to stop using the IP 10.1.100.17? because when i connect a system on VLAN 100 i cd see logs of duplicate ip on vlan
whts the command to make it nt to use it
I think the IP address might be set on that interface manually, can you post the configuration on the msfc? based on that lemme c watt exactely the problem
No the running config of msfc doesnt have anything with 10.1.100.17..this is ver ..we also run catos of 6509 switch
The IOS ver
#sh ver
IOS (tm) MSFC2 Software (C6MSFC2-JSV-M), Version 12.1(19)E1, EARLY DEPLOYMENT RE
LEASE SOFTWARE (fc2)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Mon 30-Jun-03 14:51 by nmasa
Image text-base: 0x40008C00, data-base: 0x41BCA000
ROM: System Bootstrap, Version 12.2(17r)S1, RELEASE SOFTWARE (fc1)
BOOTLDR: MSFC2 Software (C6MSFC2-JSV-M), Version 12.1(19)E1, EARLY DEPLOYMENT RE
mfl-rtr_ln_sec_6509 uptime is 28 weeks, 3 days, 19 hours, 3 minutes
System restarted at 17:29:12 BST Sat Apr 8 2006
System image file is "bootflash:c6msfc2-jsv-mz.121-19.E1.bin"
cisco MSFC2 (R7000) processor with 229376K/32768K bytes of memory.
Processor board ID SAL08332CEB
R7000 CPU at 300Mhz, Implementation 39, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
18 Virtual Ethernet/IEEE 802.3 interface(s)
509K bytes of non-volatile configuration memory.
32768K bytes of Flash internal SIMM (Sector size 512K).
Configuration register is 0x102
How do i check if the ip is assigned to MSFC..which command can i try
The cat os ver
> (enable) sh ver
WS-C6509 Software, Version NmpSW: 8.3(2)
Copyright (c) 1995-2004 by Cisco Systems
NMP S/W compiled on May 28 2004, 22:52:31
System Bootstrap Version: 6.1(3)
System Boot Image File is 'bootflash:cat6000-sup2k8.8-3-2.bin'
System Configuration register is 0x2
Hardware Version: 2.0 Model: WS-C6509 Serial #: SCA052200CC
PS1 Module: WS-CAC-1300W Serial #: SON05031858
PS2 Module: WS-CAC-1300W Serial #: SON04502667
Mod Port Model Serial # Versions
1 2 WS-X6K-SUP2-2GE SAD050608HF Hw : 2.2
Fw : 6.1(3)
Fw1: 6.1(3)
Sw : 8.3(2)
Sw1: 8.3(2)
WS-F6K-PFC2 SAD050610PM Hw : 1.3
Sw :
Sw :
3 8 WS-X6408A-GBIC SAL05217VME Hw : 2.0
Fw : 5.4(2)
Sw : 8.3(2)
4 8 WS-X6408A-GBIC SAD04310CSC Hw : 1.6
Fw : 5.4(2)
Sw : 8.3(2)
5 8 WS-X6408A-GBIC SAL06240XWX Hw : 2.1
Fw : 5.4(2)
Sw : 8.3(1152)
15 1 WS-F6K-MSFC2 SAD05060Y0K Hw : 1.2
Fw : 12.1(4)E3
Sw : 12.1(4)E3
DRAM FLASH NVRAM
Module Total Used Free Total Used Free Total Used Free
1 131072K 76831K 54241K 32768K 31626K 1142K 512K 367K 145K
I cant see the ip address assigned to MSFC anywhere. are we right to say its being used by MSFC
Once you type "show ip arp 10.1.100.17" in the MSFC, what MAC-Address you see?, & then from the "6509>(enable)show cam " is it poiting to the MSFC?
Yes, thts wht i pasted before
6509> (enable) sh cam 00-d0-04-f4-ab-fc
100 00-d0-04-f4-ab-fc R# 15/1
101 00-d0-04-f4-ab-fc R# 15/1
102 00-d0-04-f4-ab-fc R# 15/1
---------------------------------------------6509#sh ip arp 10.1.100.17
Internet 10.1.100.17 - 00d0.04f4.abfc ARPA Vlan100
but how do i make msfc not use it, wht shd i do?
Please login to MSFC and then paste the output from " show config " and " show ip int brief". It should list the address, if used by the MSFC.
What happens if you clear the ARP on msfc " clear ip arp ".
regards,
-amit singh
can you give me the output of the interface vlan 100?
show run interface vlan 100
interface Vlan100
ip address 10.1.100.2 255.255.255.0
no ip redirects
ip pim sparse-dense-mode
standby 100 priority 200 preempt
standby 100 ip 10.1.100.1
clear the arp , and ping the ip again doesnt help..if msfc is using it i cant figure why? because the config doesnt show anything line with 10.1.100.17..
This is something a strange behavior is happening. but can you tell me how many vlans are created in the msfc & make sure that this ip address is not set even as a standby IP address. this is might b silly, could you juz restart the switch during the night or day time after working hours. it might help.
