02-12-2013 06:02 AM - edited 03-07-2019 11:39 AM
I have a problem with a router not sending out ICMP unreachables when it receives a frame which exceeds the MTU and the do not fragment flag is set.
Cisco IOS Software, s2t54 Software (s2t54-IPSERVICESK9-M), Version 15.0(1)SY2, RELEASE SOFTWARE (fc4)
Mod Ports Card Type Model
1 48 CEF720 48 port 1000mb SFP WS-X6748-SFP
5 5 Supervisor Engine 2T 10GE w/ CTS VS-SUP2T-10G
interface Tunnel0
ip address 1.1.2.17 255.255.255.248
no ip redirects
ip tcp adjust-mss 1436
tunnel source 1.1.2.1
tunnel destination 1.1.2.9
tunnel path-mtu-discovery
end
Ping across tunnel:
#ping
Protocol [ip]:
Target IP address: 1.9.8.17
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: loopback0
Type of service [0]:
Set DF bit in IP header? [no]: yes
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]: v
Loose, Strict, Record, Timestamp, Verbose[V]:
Sweep range of sizes [n]: y
Sweep min size [36]: 1350
Sweep max size [18024]: 1550
Sweep interval [1]: 5
Sending 205, [1350..1550]-byte ICMP Echos to 1.9.8.17, timeout is 2 seconds:
Packet sent with a source address of 1.4.4.88
Packet sent with the DF bit set
Request 0 timed out (size 1350)
Reply to request 1 (16 ms) (size 1355)
Reply to request 2 (12 ms) (size 1360)
Reply to request 3 (16 ms) (size 1365)
Reply to request 4 (16 ms) (size 1370)
Reply to request 5 (16 ms) (size 1375)
Reply to request 6 (16 ms) (size 1380)
Reply to request 7 (16 ms) (size 1385)
Reply to request 8 (12 ms) (size 1390)
Reply to request 9 (16 ms) (size 1395)
Reply to request 10 (16 ms) (size 1400)
Reply to request 11 (16 ms) (size 1405)
Reply to request 12 (16 ms) (size 1410)
Reply to request 13 (16 ms) (size 1415)
Reply to request 14 (12 ms) (size 1420)
Reply to request 15 (16 ms) (size 1425)
Reply to request 16 (16 ms) (size 1430)
Reply to request 17 (16 ms) (size 1435)
Reply to request 18 (16 ms) (size 1440)
Reply to request 19 (16 ms) (size 1445)
Reply to request 20 (12 ms) (size 1450)
Reply to request 21 (16 ms) (size 1455)
Reply to request 22 (16 ms) (size 1460)
Reply to request 23 (16 ms) (size 1465)
Reply to request 24 (16 ms) (size 1470)
Reply to request 25 (16 ms) (size 1475)
Request 26 timed out (size 1480)
Request 27 timed out (size 1485)
Request 28 timed out (size 1490)
Request 29 timed out (size 1495)
Request 30 timed out (size 1500)
Success rate is 80 percent (25/31), round-trip min/avg/max = 12/15/16 ms
#sho run | inc unreachable
class-map match-any class-copp-icmp-redirect-unreachable
class class-copp-icmp-redirect-unreachable
#sho ip icmp rate-limit
DF bit unreachables All other unreachables
Interval (millisecond) 500 500
Log threshold (packet) 1000 1000
Log interval (millisecond) 60000 60000
Interface # DF bit unreachables # All other unreachables
GigabitEthernet1/17 0 0
Loopback0 0 0
Loopback1 0 0
Loopback224 0 0
Tunnel0 0 0
Tunnel1 0 0
Tunnel2 0 0
Vlan601 0 0
Vlan603 0 0
Vlan605 0 0
Vlan607 0 35
Vlan608 0 99
Vlan611 0 0
Vlan613 0 0
Vlan616 0 0
Vlan617 0 0
Vlan621 0 0
Vlan623 0 0
Vlan625 0 0
Vlan628 0 0
Vlan654 0 0
Vlan667 0 0
Vlan669 0 0
Vlan671 0 0
Vlan672 0 0
Greatest number of unreachables on Vlan608
I'm perplexed, and need this feature for PMTUD to work correctly on the network. Any ideas please? Thanks
Solved! Go to Solution.
02-25-2013 02:52 AM
fixed in 15.0(1)SY3 and 15.1(1)SY
02-13-2013 03:11 AM
Here is a little bit more info, if anyone finds it useful?
#sho ip int t0
Tunnel0 is up, line protocol is up
Internet address is 1.1.2.17/29
Broadcast address is 255.255.255.255
Address determined by non-volatile memory
MTU is 1476 bytes
Helper address is not set
Directed broadcast forwarding is disabled
Outgoing access list is not set
Inbound access list is not set
Proxy ARP is enabled
Local Proxy ARP is disabled
Security level is default
Split horizon is enabled
ICMP redirects are never sent
ICMP unreachables are always sent
ICMP mask replies are never sent
IP fast switching is enabled
IP CEF switching is enabled
IP CEF switching turbo vector
IP Null turbo vector
Associated unicast routing topologies:
Topology "base", operation state is UP
IP multicast fast switching is enabled
IP multicast distributed fast switching is disabled
IP route-cache flags are Fast, CEF
Router Discovery is disabled
IP output packet accounting is disabled
IP access violation accounting is disabled
TCP/IP header compression is disabled
RTP/IP header compression is disabled
Probe proxy name replies are disabled
Policy routing is disabled
Network address translation is disabled
BGP Policy Mapping is disabled
Input features: CEF Packet Capture, MCI Check, TCP Adjust MSS
Output features: IP Post Routing Processing, TCP Adjust MSS, HW Shortcut Installation
Post encapsulation features: MTU Processing, IP Protocol Output Counter, IP Sendself Check, HW Shortcut Installation, CEF Packet Capture
WCCP Redirect outbound is disabled
WCCP Redirect inbound is disabled
WCCP Redirect exclude is disabled
#sho ip int g1/17
GigabitEthernet1/17 is up, line protocol is up
Internet address is 1.1.2.1/30
MTU is 1500 bytes
ICMP redirects are always sent
Output features: IP Post Routing Processing, HW Shortcut Installation
02-13-2013 03:49 AM
If you want to test whether ICMP Fragmentation Needed messages are being sent from a router as a response to an oversized packet, do not send oversized packets from that router itself. That router is not going to send ICMP Unreachables to itself. Instead, you should send oversized packets from a different device that just routes through your router you want to test.
Best regards,
Peter
02-13-2013 04:26 AM
Hi Peter, Thanks for your input. I have already tried that and got a similar response - ie, it looks like they are not sent by the router.
02-13-2013 04:30 AM
For clarity I should also mention I've captured the packets in/out of the router and don't see any unreachables being sent when I send frames too large for the MTU on the link with the DF flag set.
02-13-2013 06:44 AM
Hello Jake,
The ICMP Fragmentation Needed will be sent when a packet with DF set arrives to a router and should be sent out a different interface whose MTU is smaller than the packet's size. Note that the packet must first be accepted, i.e. its size must not be larger than the incoming interface's MTU. What you did, if I understand you correctly, was basically a MTU mismatch on a single link. These MTU mismatches on a single link are not handled by ICMP; in fact, they are considered a grave misconfiguration.
What you need to do is to send a packet that will be accepted by the router on the incoming inteface but that is too large for the outgoing interface where the router tries to forward it through.
Best regards,
Peter
02-13-2013 07:15 AM
Hi Peter,
I'm not sure you understood correctly at all?
I'm trying to send a packet that is too large for the MTU on a tunnel, and I'm expecting to get an ICMP unreachable (type 3, code 4) back, but this is not happening and the packets are dropped even though the interfaces are configured to send ICMP unreachables, which seems strange. There is no misocnfiguration as far as I can tell, and one end of the tunnel config is shown above. The other end is configured similarly (except for the platform and IOS) and the same test from the other side of the tunnel produces ICMP unreachables.
This issue only affects A-symetric traffic as I have configured the mss tcp value to a relavant size for the IP mtu on the link (as you can see from the config). So PMTUD is not required in this instance, but for a-symetric traffic the mss is only rewritten in the header in one direction so PMTUD is required. For PMTUD to work we require the router to send ICMP unreachables which it is not doing.
I hope this clarifies the issue.
02-13-2013 07:54 AM
I admit I am having troubles understading where the oversized packets are originated and on which interface are they supposed to be dropped, along with ICMP unreachables being generated as a result. Please understand that you know your network topology and the environment; I do not - so far, I only know that you are pinging from somewhere to somewhere else and you expect ICMP unreachables to somehow be generated at some point in the network. I am struggling to understand your topology; there is not much information about it in your posts so far.
Do you believe you could draw a quick topology sketch that indicates the position of the sender of the oversized packets and the interface whose MTU is lower?
Best regards,
Peter
02-14-2013 09:19 AM
Here you go Peter, obviously the IP addresses are invalid. Quite simple really.
02-14-2013 11:12 AM
Thank you. This really helps.
This may be a blind shot but notice that on R1, your tunnel is not configured with ip mtu 1476 command while R2 is. Although the MTU on GRE tunnels should be decreased automatically, the default setting differs between different IOS versions. Can you try configuring this command on the R1's tunnel please and repeating your experiment?
Thank you!
Best regards,
Peter
02-15-2013 06:12 AM
Hi Paul, Unfortunately I tried that day one, and the behavior in this version of IOS is to not display that command in the config. The command tunnel path-mtu-discovery effectively enables MTU negotiation so the interface always should have the correct MTU, as can be seen from the below output (which was also posted above).
#sho ip int t0
MTU is 1476 bytes
07-21-2016 08:15 PM
Hello Jake,
you need to configure "ip unreachables" on the egress L3 interface towards the host.
Thanks.
02-25-2013 02:52 AM
