N5K Interface unable to connect to port-channel - command failed: port not compatible [port native VLAN]
REUBEN CHIN
Not sure what this error message means.
This is my configuration in brief:
Model:  N5K5596 using Fabric Path
Software:  version 5.1(3)N2(1)
interface port-channel101
  description xxxxxxxxxxxx
  switchport
  switchport mode fabricpath
  lacp min-links 2
  switchport trunk native vlan 999
  fabricpath isis metric 5
interface Ethernet1/37
  description xxxxxxxxxxxxx
  switchport
  channel-group 101 mode active ******  UNABLE TO APPLY THIS LINE  ******
I have configured the Native VLAN999
I have removed the Po101 and re-added it in hopes it would work, it did not work.
The features currently applied are:
feature-set fabricpath
feature telnet
no feature http-server
feature tacacs+
feature private-vlan
feature udld
feature interface-vlan
feature lacp
feature dhcp
feature vpc
feature lldp
Hoping someone has further answers, I'll cont. looking through the whitepapers for any possible answers.
REUBEN CHIN
Answered...
Removed the configuration for Po101
Configured all applicable ports which will participate with Po101
Re-Configured Po101 with the original config.
  switchport
  lacp min-links 2
Everything is working.
I always thought you could configure additional ports without modifying the actual port channel.  That is not the case.  The Port Channel must be configured last.  Adding additional interfaces after the Po has been created didn't work.
ravi.peddi1
you can't just add channel group command to the interface hoping that it will assign logical port-channel settings to physical interface. it won't work when new member is added.
make sure the port-channel type: l2/l3 and mode access/trunk
L2: add switchport cmd to the member interface.
L3: add no switchport cmd to the member interface.
Order:
1. configure the port-channel.
2. apply similar configuration of port channel to the member ports.
3. add channel-group mode xx active to the member ports.
this must work.
